Basement Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 04-08-2012, 03:00 PM   #1
basement insulation
Hi. I'm looking to insulated my basement walls. Have been researching on line the best way of going about it. I don't want to take much space away from the basement so i will stay with the fir strips on the concrete wall which is there already. My question is i will replace the fir strips with new ones, but with all the info on the net it states that you should use pressure treated fir strip to avoid mold as wood absorbs the moisture from the wall. Should I use the pressure treated fir strip or use the 1 1/2 pink foam board with grooves for the fir strip or place a thin layer of insulation behind the fir strips before nailing to wall and rigid foam between the fir strips. To much information overload. thank you for any help/suggestions.
vscarc is offline   Reply With Quote
Old 04-08-2012, 03:05 PM   #2
Rewards Points: 6,652
XPS on the walls, then use 2x4 studs for the walls, with pressure treated 2x4 for the bottom plate. You never want the wood in direct contact with the concrete wall. Buildingscience.com has all of this info.
Old 04-08-2012, 09:15 PM   #3
Rewards Points: 1,092
As do about 39 posts here. This is asked a lot, as recently as a week or so ago; search here, too.
Old 04-08-2012, 11:16 PM   #4
Registered User
Rewards Points: 5,498
Use p.t. furring, with an application of water-proofing on 6 sides as the flats will be in full contact with the wet foamboard.
http://www.greenbuildingadvisor.com/...-building-code
Gary
P.S. Welcome to the forums!
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 05:44 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
basement insulation advise needed bmartin5150 Building & Construction 1 04-27-2009 04:56 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
