Basement Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 03-17-2012, 08:34 PM   #1
Basement Insulation
I have these large white sheets of insulation coming down the walls in basement. Are they needed? Are they worth the space they take up?
mbeds is offline   Reply With Quote
Old 03-18-2012, 12:27 AM   #2
Rewards Points: 1,092
Very likely EPS insulation, and, yes, you very likely need them, though they should be covered w/ sheet rock for fire "proofing". Before you cover them, get some tape that is compatible w/ them and tape the seams, and/or goo them w/ appropriate goo (to air seal).
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 05:44 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
basement insulation advise needed bmartin5150 Building & Construction 1 04-27-2009 04:56 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
