Basement Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 10:19 AM   #1
Basement Insulation
Hello all,
I have been reading this board for a long time and it has helped me with the DIY project of finishing my basement.I have all the proper permits, and etc.
I am at the insulation phase, and had a few questions that I seem to be confused about. I have seen many discussion on this topic, but still looking for some more help.
I have insulated the entire basement (3 walls are at ground level, and 1 wall is concrete/under ground level, my basement is a walk-out basement)they are insulated with ROXUL and now I will be starting the 6mil poly vapor barrier.
My questions are in regards to tape for the seams/outlets and caulking. Do I caulk and tape at the top and bottom plates? How about the outlets, once i cut the outlet opening, do i use caulk or tape?
Which caulking and or tape should be used? I have only seen the Tyvek tape at Home Depot. Is this OK to use? Also, which caulking should be used?
I am located in MASS.
Thank you all for you help, sorry for the newbie quesitons, as I am learning as I go.
NewbieDIY is offline   Reply With Quote
Old 02-22-2012, 12:10 AM   #2
Registered User
Rewards Points: 5,516
Welcome to the forums!
I'd use: http://www.buildingscience.com/docum...study-analysis
Pick a Case # and we'll go through it in detail....
Everyone is new once.
Gary
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 05:44 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
basement insulation advise needed bmartin5150 Building & Construction 1 04-27-2009 04:56 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
