Basement Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 10-08-2011, 07:16 PM   #1
basement insulation
I have a 10 year old modular home with a poured concrete foundation that has been insulated with exterior foam insulation below grade and foam insulation with plastic sheeting below the 4" concrete floor. the basement is dry and reasonably comfortable year round
I want to create a basement apartment with steel studs and would like to knw what additional insulation I should use?
If I use blown insulation shoud it be blown on before or after I frame and would 1-1/2" studs be suitable?
cussinvinnie is offline   Reply With Quote
Old 10-10-2011, 08:21 AM   #2
Rewards Points: 1,440
Don't put batt or blown in insulation against the concrete walls or floor. No moisture barrier on the inside; you already have a moisture barrier on the outside. (The plastic sheet under the floor is a moisture barrier.)
Typical insulation requirement for the below ground portions of walls is R-13 which may have been satisfied with the foam already in place. Check your local building code (may be the standard International Building COde).
Basement insulation / vapor barrier questions deepstuff Building & Construction 16 02-09-2012 10:11 AM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 06:44 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
basement insulation advise needed bmartin5150 Building & Construction 1 04-27-2009 05:56 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
