Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 09-12-2011, 09:53 PM   #1
basement insulation
was wondering what the best way is to insulate my baasement walls and rim joist. i do get some moisture through the block walls. as far as the rim joist goes is spray foam the best and if so where is the best place to get it.
shawn
redsox1918 is offline   Reply With Quote
Old 09-12-2011, 11:10 PM   #2
Exterior Construction
Windows on Wash's Avatar
basement insulation
Spray foam in the bands is easiest and most effective air seal.
How much moisture is coming through the walls and are you sure it is coming through the walls vs. condensation?
Basement insulation / vapor barrier questions deepstuff Building & Construction 16 02-09-2012 10:11 AM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 06:44 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
basement insulation advise needed bmartin5150 Building & Construction 1 04-27-2009 05:56 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
