Basement Foundations A Wavy Mess - Wanted To Put Up 2" Xps - Insulation - DIY Chatroom Home Improvement Forum
Old 07-24-2013, 03:02 PM   #1
Basement foundations a wavy mess - wanted to put up 2" xps
Hello,
I may be one of the select few thats read this all pages of this insualtion forum, and I like to think I've learned quite a bit, especially from Gary and Windows on Wash, so thanks!
So I had the whole plan, tear out the existing walls (a moldy, improper stud spacing and insualtion, terrible electrical, and wood and drywall touching concrete) and put up 2" xps, studs, then roxul cavity insulation.
The problem I found last night is my poured founation is an uneven mess, with vertical variations up to a 1/2". Should I still use xps? That stuff doesn't bend at all, which means there will be gaps behind it.
I'll try and get a picture up tonight to show you what I mean.
Thanks in advance for any advice. Unless that advice is spray foam, then I'll have to work weekends for the next 4 months.
Jason
Deseloth is offline   Reply With Quote
Old 07-24-2013, 05:17 PM   #2
Rewards Points: 6,652
Take a line stretched across the wall to find the highest poit. Then use a laser to keep the wall straight and true an inch off. After done pulling any plumbing, electrical, low voltage witing, use Spray foam to seal the space.
If you still want to use blue foam board, you would have to use shims cut from it, or glued on the back of the framing, to keep it against the wall.
Old 07-26-2013, 11:57 PM   #3
Registered User
Rewards Points: 4,912
Use thinner layers of board to meet your thickness goal. Make sure it is air-tight on concrete.http://joneakes.com/jons-fixit-database/743
No gap to insulation from foamboard for convective loops; https://docs.google.com/viewer?a=v&q...fHFsk1RrK9G2HQ
Drywall; http://www.buildingscience.com/docum...wall-approach/
Gary
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Humid but not wet basement...is dryloc enough? iwannadoit Concrete, Stone & Masonry 9 07-30-2013 06:31 PM
Insulating basement - questions jtmann HVAC 7 11-19-2010 04:20 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Basement Finishing Advice Wanted PJU1971 Carpentry 4 04-04-2009 05:04 PM
