Basement - Built Wall 6" Out From Concrete Wall - Insulation - DIY Chatroom Home Improvement Forum
Old 06-11-2013, 02:07 PM   #1
Basement - built wall 6" out from concrete wall
Hi there,
I live in Toronto.
I just finished framing my basement.
Before I framed it , I deliberated on the ENDLESS amount of opinions on the best way to do the insulation. - I decided to place my studs approx. 1/4" - 1/2" out from concrete wall , fiberglass batting between the studs , poly vapor barrier on the outside of the studs.
I have had many people tell me that I'm doing it wrong and that the vapor barrier should be on the concrete wall , or on both the cold and warm sides, etc., but that's not really my question here...
While framing , I encountered a situation where it made sense to place a 9' section of wall about 6" out from the cement (as opposed to 1/4"). Given the way that I have decided to insulate , should I still put fiberglass bats between the studs and poly over top (leaving a 6" deep x 9' long x 7' high pocket in between the insulation and the concrete) , or should I do something else like applying insulation directly to the concrete?
Any opinion would be great.
Cheers.
Bill Shears is offline   Reply With Quote
Old 06-11-2013, 03:09 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Bill Shears View Post
I just finished framing my basement. ... I deliberated on the ENDLESS amount of opinions on the best way to do the insulation. - I decided to... I have had many people tell me that I'm doing it wrong...
nuh uh.
Old 06-12-2013, 07:04 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,274
I wouldn't put any batt insulation in direct contact with the concrete in this case.
I hope the grading and foundation water management are spot on for your home.
With all that you read on here, I am surprised that you arrived at this option.
Old 06-12-2013, 07:05 AM   #4
Originally Posted by TarheelTerp View Post
nuh uh.
Old 06-26-2013, 01:00 AM   #5
Registered User
Rewards Points: 526
http://www.buildingscience.com/docum...Insulation.pdf
Gary
PS. Welcome to the forums!
breaking up concrete near basement wall benleef Concrete, Stone & Masonry 12 02-12-2013 03:58 PM
Insulating Uneven Basement Wall Help (with pics) jefferyscott Building & Construction 3 02-01-2013 11:32 AM
Need to Install Hand Rail on Basement Stairs, but on Concrete Wall Firehawk734 Building & Construction 40 01-18-2012 08:33 AM
How to insulate 1' concrete wall that meets 8' studded wall Truth Insulation 7 01-16-2012 08:14 PM
Hole in concrete basement wall... viggen Building & Construction 1 06-06-2011 08:32 AM
