Basement With 2x4 Walls And 2" Airspace - Insulation - DIY Chatroom Home Improvement Forum
Old 11-24-2013, 02:00 PM   #1
Rewards Points: 169
Basement with 2x4 walls and 2" airspace
Just wanted to check before I started a project on my basement walls.
I have 2x4 studs and a 2" airspace. It's currently only "insulated" with some sort of aluminium foil.
I'm thinking that I'd put 1" or 1.5" rigid board between the studs, tucktape them and then put in R20 cellulose.
I'd gave to cut the rigid board to fit between the studs.
RCGA is offline   Reply With Quote
Old 11-24-2013, 03:58 PM   #2
Rewards Points: 13,458
#1 Going to have to go back and add your location to your profile.
#1 Please explain how if this is a basement why is there wood on the back side of the studs.
Old 11-24-2013, 03:59 PM   #3
Rewards Points: 169
St. John's, NL, Canada
Concrete, not wood.
Old 11-24-2013, 04:10 PM   #4
Sure looks like 1 X 6 pine behind those studs which will cause rot and mold to form from being in direct contact with the concrete behind it.
Old 11-24-2013, 04:19 PM   #5
Rewards Points: 169
It's concrete. I guess they poorded the foundation using 1x6 framing.
Plug a 2" drain in basement poorboy01 Plumbing 0 11-05-2013 09:23 AM
Basement insulation - 2" rigid foam diggerd Insulation 5 10-09-2012 07:24 AM
2" space between poured concrete walls and concrete slab floor PKEARTH Concrete, Stone & Masonry 0 09-30-2012 03:50 PM
Exterior walls are only 2" deep! Fastballoon Building & Construction 6 04-29-2011 11:48 AM
So I just added 2" of insulation to my outside walls... muthian Remodeling 1 12-30-2010 10:35 AM
