Balsam Wood Batts? - Insulation - DIY Chatroom Home Improvement Forum
Old 12-04-2011, 07:22 AM   #1
balsam wood batts?
Can I put fiberglass batts over balsam wood batts. It wood very messy to remove the wood batts.
Laura Braun
Columbus, OH
rocketfnn is offline   Reply With Quote
Old 12-04-2011, 07:32 AM   #2
Rewards Points: 13,450
A lot more detail please, and a picture would sure help.
Where are the batts, on the walls, ceiling.
Old 12-04-2011, 07:45 AM   #3
Thank you for the reply.
The insulation batts are stapled to the wood ceiling joists similar to a fiberglass insulation.
The "batts" are balsam wood insulation on the brown paper bag.
The house is 1950 built and the bags are very easily damaged.
We took down the old wood ceiling panels in this Cap Cod dormer and found this stuff. Could be put batts over it?? It is messy stuff if the bags are cut.
Laura
Old 12-04-2011, 09:29 AM   #4
Rewards Points: 6,652
No. I would personallly remove all of the old, and install new. Use Roxwool vs Batt fiberglass.
Old 12-04-2011, 11:06 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,086
If it is a cape, make sure your vent chutes are in place (rigid foam would be ideal in this case.
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 03:14 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
