Baffle Distance - Insulation - DIY Chatroom Home Improvement Forum
Old 05-07-2014, 07:32 AM   #1
baffle distance
All the pictures I see of baffles shows them "in between" the roof rafters with one to two inches of air space between the baffle and the roof sheathing. Is there any reason why I can't do it like this (as it is easier for me). There is 7 inches between the roof sheathing and the baffle. Doesnt that "allow" a nice flow of air from the soffit to the attic. I will air seal where needed, then put back the fiberglass that was there and then blow in about 8-10 inches of cellulose. Is this Ok??
simagic is offline   Reply With Quote
Old 05-07-2014, 10:40 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,164
No reason.
Get the top plate sealed up though before getting the baffles in there.
Old 05-07-2014, 11:10 AM   #3
sorry for my "novice-ness". the top plate is where the sheet rock from the ceiling below meets the (wood) just inward of the sofit vent . The baffles I made actually "rest" on top of the top of this wood. I intend to "great stuff" the bottom of the baffles ( on "my interior side" where I can reach it , against the top plate). Sooooo the bottom of the baffle is sealed onto the top plate. If you look where the sheetrock meets the baffle you can see some wood ( which I believe is the top plate . Will this be good??
Old 05-07-2014, 11:35 AM   #4
47_47's Avatar
Rewards Points: 50
consider changing the flex duct to an insulated one
47_47 is offline   Reply With Quote
Studor vent distance? heinlein0311 Plumbing 3 11-08-2012 04:16 PM
Infrared Thermometer Minimum Distance to Target? justplumducky Tools 6 09-23-2012 10:52 AM
Hallmark Baffle Help MetalDemon HVAC 3 06-01-2010 10:58 AM
Where could I get something like this powered baffle. Hossenfeffer HVAC 6 04-05-2010 10:40 AM
AC unit distance to out side compressor gene380 HVAC 4 06-28-2008 09:26 AM
