Attic Ventilation - Insulation - DIY Chatroom Home Improvement Forum
Old 06-06-2012, 12:57 PM   #1
Attic ventilation
I have a hip roof. My attic needs good ventilation badly to prevent molds from growing. One estimate recommends power venting, another recommends continuous ridge vents, and more soffits. I would like safety in my house too. I've read one customer comment that used power venting, where his house almost burned do twn, but was caught early because a neighbor saw smoke coming from the roof and then fire ignited.
Please advise. Thank you. I. Haug
ERigby is offline   Reply With Quote
Old 06-06-2012, 01:45 PM   #2
With mensuration formulas and some fussing you can figure out the volume of your hip roof attic in cu. ft., then ventilate with 5 to 60 Air Changes per Hour, with the average being 10.
That fire was a fluke unless his wiring to the fan was faulty or he ignored the fan installation instructions.
Old 06-06-2012, 04:52 PM   #3
Had the same problem. Builder put in soffit venting then the insulation installers stuffed insulation and blocked most of them. I cleaned out what I could reach but it wasn't enough and still had moisture problems. I then installed 2 turbine vents and they pull enough air to have solved the problem.
The Hammer is offline   Reply With Quote
Old 06-07-2012, 11:59 PM   #4
Registered User
Rewards Points: 526
Check your required NFVA: http://www.airvent.com/homeowner/pro...it-specs.shtml
Be sure the fan is rated for the space: http://www.nachi.org/attic-ventilati...s-part1-25.htm
Have you air-sealed the attic yet, to stop the moisture from below (stack effect): http://www.wag-aic.org/1999/WAG_99_baker.pdf
http://www.google.com/url?sa=t&sourc...wWATQw&cad=rja
Do you have mold growing now? Where are you located?
Gary
Attic ventilation tmaher HVAC 5 06-09-2011 10:54 PM
Improve attic ventilation? Greenmaze Roofing/Siding 28 07-22-2010 02:16 AM
Attic Ventilation. Just double checking before I start ... :) matjam68 Roofing/Siding 11 03-16-2010 08:38 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
Proper Attic Ventilation kmhill35 Roofing/Siding 2 04-01-2005 08:11 PM
