Attic Intake Vent Advice - Insulation - DIY Chatroom Home Improvement Forum
Old 03-13-2014, 11:02 AM   #1
Attic intake vent advice
Hello,
I bought this 1898 house a year ago, and the attic of the back half of the house has no insulation. My heat bill is pretty outrageous (obviously), and I've also been getting horrible ice dams. I've already sealed up the air leaks, and I am planning on blowing in cellulose under the floorboards and then adding batt on top to bring it up to about R60. The roof is about 5 years old; it does have a ridge vent, but it has no soffit vents. The soffit is only about 6" and it is at a steep angle which is going to make it difficult to get any tools in there to make cuts for vents (see attached photos). Does anyone have any experience with soffits like this or any advice? I think I MAY be able to get a right angle drill & hole saw in there to make cuts for circular vents, but from what I've been reading on this forum it sounds like continuous soffit vents are the way to go. Problem is I've yet to find a saw that looks like it would fit in there. There is a 16" x 24" window in the attic, the top of the which starts 5' down from the peak of the ridge. Would this provide any intake venting? Thank you in advance for any advice!!!
MikeMKE is offline   Reply With Quote
Old 03-13-2014, 11:30 AM   #2
iminaquagmire's Avatar
Rewards Points: 338
Would it be possible to cut the nails holding the soffit in place? Depending on how it was put together, it might be easier just to remove the existing soffit and replace entirely with continuous aluminum or vinyl vented soffit.
iminaquagmire is offline   Reply With Quote
The Following User Says Thank You to iminaquagmire For This Useful Post:
joecaption (03-13-2014)
Old 03-13-2014, 12:39 PM   #3
Rewards Points: 402
They actually make intake vents now that are a part of the first row of shingles. I think they were by air vent. You would have to take up the first couple rows of shingles, then cut a 1" wide slot about a foot up from the edge of the roof, then put this plastic piece that raises the shingles up about an inch and provides intake ventilation. Then I think you still need baffles on the inside roof side before you put in insulation. Might be the best way in your case.
http://airvent.com/homeowner/product...-theedge.shtml
taylorjm is offline   Reply With Quote
Old 03-13-2014, 04:06 PM   #4
Rewards Points: 13,446
http://www.dciproducts.com/html/smartvent.htm
Old 03-13-2014, 04:15 PM   #5
Rewards Points: 402
Doesn't the soffit already have continuous venting in it? It looks like it in the pic. Where does it go?
Old 03-13-2014, 05:20 PM   #6
There is vinyl soffit, but it is not vented. I attached a picture from a little closer up. Behind that is solid wood...I'm not sure how thick though.
Thank you for the suggestions! I'm hoping to avoid having to remove shingles or removing the soffit board completely, but it's starting to look like I may have to.
Old 03-13-2014, 05:54 PM   #7
Rewards Points: 402
In order to fix your ice dam issues, I think you are going to have to remove that soffit, drill some big holes in the wood, and put vented soffit back up, just to get some air circulation under that eave.
So is the attic blocked of from that little soffit area?
Old 03-13-2014, 08:09 PM   #8
No, but it's an even tighter squeeze from the inside.
Anyone know if this window (16" x 24") on the north end might provide adequate intake ventilation?
Old 03-13-2014, 08:54 PM   #9
Rewards Points: 402
Well, just my opinion, but here is what I would do. I would take out the soffit and put in some vinyl vented soffit. I think you could take it out and replace it without having to remove the gutters or anything else. That vinyl soffit is pretty flexible, and it's such a short amount I wouldn't worry about nailing it in place. That way you would get some intake venting and should take care of your ice dams, just make sure you don't fill the gap with insulation. Ideally if you could slide some baffles down to the vented area and staple them up to the roof, that would direct the heat up and out the roof vent. Again, just my opinion.
Old 03-13-2014, 08:55 PM   #10
Rewards Points: 402
Wow, you can tell by the framing of that wall they used any and everything to build a house back then!
Old 03-14-2014, 12:19 AM   #11
Registered User
Rewards Points: 5,466
Considering the rafters carry the roof loads rather than the wall, I wouldn't loose sleep over it. Lead carpenter under-ordered the longer balloon-frame studs... or the apprentice cut them up.
If you add vinyl soffit, be very careful to get one with enough NFVA considering your shallow soffit (-6"). Only a few will meet the required 9 sq.in. per foot requirement for a 150/ and you need twice that amount; http://bluelinxco.com/Portals/0/docs...20Brochure.pdf
And; http://www.certainteed.com/resources...tspecsheet.pdf
Better to use this 20 NFVA, continuous; http://www.gaf.com/Roofing/Residenti...ndereave_Vents
Gary
PS. No, the window is too low in attic for exhaust vent.
Old 03-14-2014, 06:17 AM   #12
Rewards Points: 402
I think he was talking about using the window as the intake vent, at least that's the impression I got, and using the ridge vent as the exhaust.
Old 03-14-2014, 12:52 PM   #13
Yeah I was talking about the window as an intake.
Old 03-14-2014, 10:15 PM   #14
Registered User
Lol, yes, I see I missed that, plain as day.... reminder- set earlier bedtime...
Window is not at rafter bottoms for the intake. Very poor set-up, IMHO.
Gary
Old 03-24-2014, 01:30 PM   #15
Did you get your venting and insulating questions taken care of ?
dunngee is offline   Reply With Quote
Attic Ventillation Problem. Why Now? Hubs Roofing/Siding 2 03-19-2013 10:23 AM
Ridge Vent vs Attic Fan?? Different info from pro roofers MrsJoseph Roofing/Siding 31 03-08-2013 05:27 PM
where to duct laundry vent in attic? daluu HVAC 11 11-09-2012 04:25 AM
Attic intake ventilation beerdog Roofing/Siding 0 08-02-2011 08:19 AM
is an attic vent required for cedar shingle roof? walenta Building & Construction 2 10-25-2007 10:31 AM
