Attic Insulation And Vapour Barrier - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-25-2012, 11:55 AM   #16
Rewards Points: 95
Originally Posted by Fantastic View Post
I'll have to measure the span but I'm not back to the cottage till the 2nd of Aug....
This cottage will have very cold and very hot conditions. Lows down to -30C and highs to 30C.
I appreciate all the feedback folks! Keep it coming
Dealing with cold is easy, dealing with both hot and cold can be a problem.
Do you intend to live there in both winter and summer?
Are those windows double glazed? And if so how wide is the space between the glass. How many square feet of window do you have?
Are the window frames aluminium, plastic or wood?
What is the floor made of? Is there a space under?
What are the walls made of?
Perry525 is offline   Reply With Quote
Old 07-25-2012, 02:32 PM   #17
Ok, the cottage will be a year round spot.... Very little in winter. Just a couple ice fishing/snow mobile trips. Mainly a summer spot.
The windows will be replaced with new ones over time. The are aluminum framed.
The subfloor is ply wood and it's carpeted. Insulated underneath as its off ground construction.
The walls are plywood with foam board insulation.
Here's a pic of the side just so you have an idea
Fantastic is offline   Reply With Quote
vapour barrier on ceiling of bathroom? wilsonfrench Building & Construction 20 01-29-2012 08:08 PM
Insulation in the attic when the furnace is up there Jimmybrp Insulation 2 12-11-2011 02:26 PM
Old paper-backed insulation = Vapour Barrier? billyh Building & Construction 3 03-15-2011 08:38 PM
Vapour Barrier instead of Insulation giannit Building & Construction 3 01-20-2010 04:10 PM
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 08:56 AM
