Attic Insulation - Strange Pipe - Insulation - DIY Chatroom Home Improvement Forum
Old 11-05-2013, 12:45 PM   #1
DIY'er
Rewards Points: 31
Question
I was trying to get my attic insulated better, and ran into a pipe that I couldn't figure out what it was for. It is a relatively thin walled white pipe and has no markings on it. I have accounted for all of the vent pipes for the bathrooms, so I'm thinking that it isn't a vent pipe. The vent pipes all penetrate the roof and look to be a thicker walled PVC and have black markings.
Since it is next to the furnace flue, I checked the basement to see if it originates there, but couldn't see anything like it.
I thought that it might have been installed as a future way to run wires. If that is the case, then why didn't they run the bundle of wires near the flue through it?
I'm not sure that I can find out where it goes without tearing into the wall of the void it runs through.
I was tempted to cap it off, but I ended up extending it up a couple of feet so it would not get buried under the new insulation that I was blowing in. I would still like to know what is up with that pipe.
gpraceman is offline   Reply With Quote
Old 11-05-2013, 01:47 PM   #2
Rewards Points: 13,964
Anyway there used to be a hot water heater up there?
SCH is sometimes used on the relief valves.
Old 11-05-2013, 02:17 PM   #3
Rewards Points: 42
Tie a weight to a length of string and drop it down the pipe. When it stops, mark the string, pull it out, and then measure the distance traveled. It might give you a clue where is goes. The weight might stop early if there is a 90 degree bend in the pipe.
Dan
djlandkpl is online now   Reply With Quote
Old 11-05-2013, 03:12 PM   #4
DIY'er
Rewards Points: 31
There hasn't been a water heater in the attic. This is a two story house, built in 2000, with the furnace and water heater down in the basement.
Old 11-13-2013, 08:48 AM   #5
CitadelBlue's Avatar
Rewards Points: 97
Maybe someone thought ahead.... Since the pipe is running parallel to the furnace flu in the basement ..... it could be a conduit for future electric, cat and cable wires from the basement to attic/2nd floor....
Ken
Because you NEVER have enough room .........
See my Trailer and Hitch Thread
CitadelBlue is offline   Reply With Quote
Old 11-13-2013, 10:46 AM   #6
DIY'er
Rewards Points: 31
I could not find the end of that pipe in the basement. The flue goes down a void space. How far that pipe goes down the void, I'm not sure, as that would mean tearing open drywall. If it was meant as a wire run, I would have thought that they would have run the bundle of alarm and coax wire, that you can see near the flue, through it.
Now that adding more blown in insulation to the attic is done, I'm not sure that I want to disturb it to try djlandkpl's suggestion. If I have a compelling reason to go into the attic in the future, I'll give that a try.
Old 01-01-2014, 02:25 PM   #7
Professional nut buster
Rewards Points: 26
Did you take a whiff and detect any odors coming from it?
Dragfluid is offline   Reply With Quote
Old 01-03-2014, 08:45 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,234
I am going to guess some venting but depending on the age of the home, it should have been through the roof.
Perhaps a conduit as mentioned before.
The string method will give you the stopping point.
Ideas for retrofitting baffles/insulation in vaulted ceiling of built out attic room rachelsue20 Insulation 5 04-28-2012 07:49 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 03:05 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
Attic Insulation Installation oktooma Building & Construction 3 10-29-2008 03:46 AM
