Attic Insulation: Should I Use Fiberglass Or Cellulose? - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 09:22 PM   #16
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,044
My pleasure.
If I didn't believe is what I posted, I wouldn't argue the point.
At the end of the day, the people that post regularly on these type forums do so because they want the folks like you to get the best product/installation for your application.
Debate is usually a healthy thing.
Old 11-10-2011, 09:36 PM   #17
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
Originally Posted by Windows on Wash View Post
My pleasure.
Absolutely. And I appreciate the input, if I didn't want to learn I wouldn't ask the questions... and of course, when the answers aren't what I expect I tend to want to dig.
(I own a dog forum, where we have the occasional member who wants to hear nothing but "you are doing exactly the right thing" no matter what they are doing or how they are doing it.)
mnp13 is offline   Reply With Quote
Old 11-11-2011, 09:03 PM   #18
Registered User
Rewards Points: 5,482
Just to touch base on a few points.....
F.g. gets wet, usually the paper backed drywall does also, then molds, unless caught right away: http://www.inspectapedia.com/sickhou...rglassMold.htm
So, you would probably throw away any insulation that got wet by more than diffusion, which cellulose handles much better- dispersing it through all. Fiberglass requires an air-tight surface on all six sides to achieve its R-value- exactly as in a lab, hard to do in an open-to-the-outside air ventilated attic. So don't think you are getting R-? because the top layer of blown-in/batt is exposed to air movement/cold outside air = expect a severe reduction. http://books.google.com/books?id=3kL...201991&f=false
A housewrap would help, but again hard to install 100% coverage. 2" of cellulose over the top or an insulation blanket would stop the convective looping. Any air movement can degrade your f.g. up to 40%, gaps at the batts- up to 60%: http://www.aecb.net/PDFs/Impact_of_thermal_bypass.pdf
Cellulose is air-permeable as is f.g. but it handles air leaks much better: http://findarticles.com/p/articles/m...6/ai_n8582994/
Especially if you skip the most important step in insulating---------- air sealing http://www.jlconline.com/cgi-local/v...170a32100a05c7
Cellulose and f.g. are subject to wind-washing near the soffit vents (there should be baffles in place), unless a h.w. is installed to the attic in new construction: http://www.buildingscience.com/docum...ty-insulation/
Good picture of ww: http://www.arc.thermaldr.com/res_pg_3.htm
Another attic-cat……. I seem to be repeating myself, lol. At 0.53# density, it matches the twice failed testing of f.g. insulation, and they haven’t changed it yet…….check your density: Blown in insulation question?
ps.- f.g. is great for finding air leaks from below: http://www.finehomebuilding.com/PDF/Free/021105092.pdf
Gary
Old 11-12-2011, 09:04 PM   #19
mnp13's Avatar
Rewards Points: 512
Another question on this - can you "dense pack" blown in fiberglass?
My joists are 2x12's and someone suggested that I put boards down and fill the resulting "capped" cavities with fiberglass. Or the reverse - put bats in the cavities and then put 4x8 sheets of plywood over them. That would be outrageously expensive, but I'm curious about the resulting R-values.
All theoretical until I have the attic re-wired, but that's just giving me more time to thing of things to drive myself crazy.
And back to cellulose - 10 inches of cellulose won't even make it to the top of my joists, I'd need 12 to come even, and then I'm guessing there is a recommended amount that the joists should be buried for even R-value coverage? Am I going to need to fill this 16-18 inches deep? And if so, that's going to be close to 2 pounds per square foot on the back of my plaster and lathe ceiling. Is that going to crack my plaster over time? Would it make sense to put a barrier (plywood or USB) over the tops of the joists, creating a "floor" and then put down the insulation over that so that the load is spread across the joists and not the lathe? That just seems like a lot of weight for all of those little lathe nails.
Old 11-13-2011, 12:35 AM   #20
Rewards Points: 156
If I'm concerned about too much weight on the ceiling dry wall is it possible to install BOTH blown-in fiberglass and cellulose? Is it possible for me to blow in about 5 inches of fiberglass and 2 inches of cellulose on top of it for the best performance at the lowest weight?
strategery is offline   Reply With Quote
Old 11-14-2011, 11:10 AM   #21
Dense packing fiberglass will ultimately yield you a very low R-value and if you pack it tightly enough...close to that of glass.
You can blow in fiberglass and they blow in a 5" cellulose cap if you are worried about weight.
I personally have not observed any issues with the weight of cellulose but that does not mean the potential is not there.
The "biggest loser" in fiberglass insulation.... Gary in WA How To Guides 2 01-20-2015 06:19 PM
Damp Insulation in Attic wiz561 Building & Construction 6 12-23-2010 11:16 PM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-02-2010 11:38 PM
cellulose over blown in fiberglass? deerhunter Building & Construction 1 10-29-2010 10:16 PM
Attic Foam Board Insulation JasonCA Roofing/Siding 3 10-07-2010 12:56 AM
