Attic Insulation Question - Insulation - DIY Chatroom Home Improvement Forum
Old 02-06-2012, 07:27 PM   #1
Hey all,
This is my first post. I'm in the process of buying a house and my fiance and I will be closing on it on March 2nd. The attic will need to be insulated after we move in. There's only 3 inches in the main area of the house and none in the addition they added on in the 60's. We'd like to do cellulose blow in insulation ourselves. What I'm confused on right now is if we need a vapor barrier. What is common practice? We are in central IL (Peoria, IL area)
Thanks!
Matt
mfrauenhoffer is offline   Reply With Quote
Old 02-06-2012, 10:31 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I never see vapor barriers in attics.
titanoman is offline   Reply With Quote
Old 02-07-2012, 07:44 AM   #3
Rewards Points: 940
Check out your ventilation first. You may have to install some baffles along the edge from the soffit up towards the ridge.
This is always a real pleasure to do after the fact.
Then you want to blow in r-50 of cellulose.
No vapor barrier.
cleveman is offline   Reply With Quote
Old 02-07-2012, 08:55 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
No vapor barrier (at least not as most people think of it).
Air Seal and insulate.
Old 02-07-2012, 04:12 PM   #5
Thanks everyone...that's what I was thinking.
Air seal, soffit vent chutes, and insulate. Sounds like a plan!
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 09:49 AM
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 08:21 AM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 08:08 PM
Attic Insulation tim1218 Insulation 4 09-07-2011 11:18 AM
Attic insulation bids and soffit vents-need input nolamar Insulation 7 05-14-2011 11:04 PM
