Attic Insulation Question - Insulation - DIY Chatroom Home Improvement Forum
Old 02-03-2012, 08:55 AM   #1
Attic insulation question
I have a network of insulated flexable heat lines sitting on blown in insulation. In the winter, I get an ice dam in a gutter. I suspect the duct work is letting off enough residual heat to cause a slight roof melt leading to ice. I decided to buy that insulation that resembles foil faced bubble wrap and cover the flexable duct work. My question, will covering those lines cause some sort of barrier that might cause mold in the future?
MrBillCSI is offline   Reply With Quote
Old 02-03-2012, 10:25 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,770
Where is the ice dam forming.
Google "Air-Sealing" and insulation.
Ice dams are a result of bulk heat loss through any number of sources. Unsealed ductwork is certainly one of those but not the most significant in most homes cases.
You need to air seal, add insulation, inspect venting, and make sure the envelope layer is tight.
If the ductwork is tight, drop them down into the insulation layer and blow additional insulation over the top of them. This will help with the radiant heat loss 100X more than the radiant heat barriers.
Radiant barriers are mostly crap in about 99% of the applications that homeowners and contracts try to use them for. They only work with an air space so in this application, they will do nothing for you but, as you theorized, potentially create a double vapor retarder layer and mildew/mold issues.
Any ill-effect on the house if without attic insulation? htabbas Insulation 12 01-02-2012 10:30 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 09:49 AM
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 08:21 AM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 08:08 PM
Attic Insulation tim1218 Insulation 4 09-07-2011 11:18 AM
