Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 10-12-2011, 09:37 PM   #1
Attic insulation over whole house fan
We have an old inoperable whole house fan. I'd like to insulate above it in the attic. Can I just put faced insulation over the louvers? Is there a better way of insulating this fan? The shutter cover that I found on line only has an R value of 6.
D Lee is offline   Reply With Quote
Old 10-12-2011, 09:43 PM   #2
Missouri Bound's Avatar
...a couple of things. 1. Remove the entire unit and install drywall and tape, then insulate properly.
2. Are you sure you want to stop using the fan? They are great energy savers.
Old 10-13-2011, 12:43 PM   #3
Exterior Construction
Windows on Wash's Avatar
+1
Best thing to do would be to build a rigid, airtight enclosure around it for the winter months (rigid foam board with a drywall layer is fine) and have a top to it.
Pop the top in the summer months and use the fan as intended.
Best of both worlds.
Old 10-13-2011, 04:18 PM   #4
Originally Posted by Windows on Wash View Post
+1
...and that IS a better idea
How to handle insulation on Cape Style House ksuclipse Insulation 8 09-16-2011 09:56 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 01:42 PM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-03-2010 12:38 AM
Attic Foam Board Insulation JasonCA Roofing 3 10-07-2010 01:56 AM
Attic Insulation - Do's and Don'ts reikiray HVAC 1 07-27-2007 11:21 AM
