Attic Insulation And Joist Addition? - Insulation - DIY Chatroom Home Improvement Forum
Old 01-29-2013, 07:28 PM   #1
attic insulation and joist addition?
My attic only has r11 or r13 insulation. It has some plywood layed down for storage. I was wonderin if i could tear up the plywood and put 2x4s or 2x6 running 90 degrees to the celing joists then adding more insulation and plywood so i can keep my storage space. Will this work? Or is there a better way of adding insulation and and keeping my storage space.
kevin07 is offline   Reply With Quote
Old 01-30-2013, 01:53 AM   #2
Rewards Points: 14,312
By fair most attics where never designed to be used for storage.
What's the width of the joist and the free unsuppoted spans?
Makes no since to add even more weight if they were not built wide enough in the first place.
You'll end up with ceiling damage.
http://www.energystar.gov/index.cfm?...sulation_table
Old 01-30-2013, 06:18 AM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
In most cases, your best bet is going to be to set aside a small area for storage (if you must), and then seal and insulate the rest of the attic properly. If the plywood is loose, pull it out and blow in what you need, or if it is secured already you can dense pack underneath it and blow over the top.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Insulation in the attic when the furnace is up there Jimmybrp Insulation 2 12-11-2011 02:26 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Attic Insulation paige2 General DIY Discussions 21 03-16-2011 10:35 AM
