Attic Insulation Install Old Over New? - Insulation - DIY Chatroom Home Improvement Forum
Old 10-08-2012, 09:00 AM   #1
Rewards Points: 49
Attic insulation install old over new?
Is there advantage to removing blown in insulation thats 20+ years old and installing new insulation?
Or can it be installed over the old without detriment?
Is there a cheap plastic grating that helps to walk/crawl around in the attic?
If you want to install new cieling drywall,
Should you remove the insulation before removing the drywall cealing?
thx
john_bry is offline   Reply With Quote
Old 10-08-2012, 02:41 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,926
As long as the old insulation isn't contaminated, it isn't hurting anything.
Old 10-08-2012, 03:30 PM   #3
Rewards Points: 13,300
I would make sure everything got air sealed before adding more insulation.
Just rip some 3/4 OSB for walk boards.
I duct tape a piece of 3" PVC to the hose so I can hit all the outsides while standing in the middle.
Make sure to add plastic or foam baffles in the rafter bays near the soffits so they do not get blocked up.
Where is this sheetrock your talking about? On the attic ceiling?
Got any pictures?
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 09:49 PM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 02:54 PM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-03-2010 12:38 AM
Attic Foam Board Insulation JasonCA Roofing/Siding 3 10-07-2010 01:56 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 10:57 AM
