Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 08-24-2012, 11:21 PM   #1
attic insulation identification
Hi I am, trying to identify some insulation in a home that was built in 1910. There is no access to the attic except for a small opening in the bathroom where an exhaust vent is installed. I was able to pop my head through and looks like 6-7 inches of insulation. I am not exactly sure, so I was hoping someone might be able to ID it for me. I have attached a pic. It's kind of wool like and fibrous.
tiki16 is offline   Reply With Quote
Old 08-25-2012, 08:18 AM   #2
Exterior Construction
Windows on Wash's Avatar
Looks similar to cellulose.
If there is 6-7" of it, it certainly isn't original to the home.
Old 08-25-2012, 08:44 AM   #3
I don't know how they got up there to insulate as the only opening I have found is in the bathroom where the ceiling fan is. I am surprised that there is 6" of insulation. It's hot in the summer and cooler in the winter on the 2nd floor.
Is it worthwhile to add more insulation?
thanks
Old 08-26-2012, 12:21 PM   #4
Yes.
Most homes and climate regions recommend 12-14" of a loose fill insulation.
Old 08-26-2012, 12:31 PM   #5
http://www.energystar.gov/index.cfm?...sulation_table
It should be that big a deal to make a new acess hole. Sometimes there in attic ceilings so they do not show as much.
What type roof venting do you have.
What type roof do you have?
Old 08-27-2012, 08:32 AM   #6
do you mean "closet" ceilings ?
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 08-28-2012, 12:11 AM   #7
Moderator
It appears to be rock wool, second photo, hold "control key" and hit "Plus key" repeatedly, use "arrow keys" to find it on page;http://inspectapedia.com/interiors/R...Insulation.htm
Hold control, hit "minus key" to reduce again.
Gary
Clothes taking longer to dry?
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 02:54 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 09:49 AM
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 08:21 AM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 08:08 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 03:10 PM
