-   Insulation (http://www.diychatroom.com/f103/)
-   -   attic insulation identification (http://www.diychatroom.com/f103/attic-insulation-identification-154761/)
tiki16 08-24-2012 11:21 PM
1 Attachment(s)
Hi I am, trying to identify some insulation in a home that was built in 1910. There is no access to the attic except for a small opening in the bathroom where an exhaust vent is installed. I was able to pop my head through and looks like 6-7 inches of insulation. I am not exactly sure, so I was hoping someone might be able to ID it for me. I have attached a pic. It's kind of wool like and fibrous.
Windows on Wash 08-25-2012 08:18 AM
Looks similar to cellulose.
If there is 6-7" of it, it certainly isn't original to the home.
tiki16 08-25-2012 08:44 AM
How much insulation is needed
I don't know how they got up there to insulate as the only opening I have found is in the bathroom where the ceiling fan is. I am surprised that there is 6" of insulation. It's hot in the summer and cooler in the winter on the 2nd floor.
Is it worthwhile to add more insulation?
thanks
Windows on Wash 08-26-2012 12:21 PM
Yes.
Most homes and climate regions recommend 12-14" of a loose fill insulation.
joecaption 08-26-2012 12:31 PM
http://www.energystar.gov/index.cfm?...sulation_table
It should be that big a deal to make a new acess hole. Sometimes there in attic ceilings so they do not show as much.
What type roof venting do you have.
What type roof do you have?
Fix'n it 08-27-2012 08:32 AM
do you mean "closet" ceilings ?
Gary in WA 08-28-2012 12:11 AM
It appears to be rock wool, second photo, hold "control key" and hit "Plus key" repeatedly, use "arrow keys" to find it on page;http://inspectapedia.com/interiors/R...Insulation.htm
Hold control, hit "minus key" to reduce again.
Gary
