Attic Insulation - How To? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 12:11 PM   #1
Signal Guy's Avatar
Attic Insulation - How to?
Hi,
Something Iíve been confused about is attic insulation. Iím planning to insulate before next winter, but Iím not sure which way to go about it.
I live in NE Ohio. When I was young, my Dad, & I insulated our attic but installing foil-faced insulation between the eaves. This enabled us to use the attic as storage/living space.
Now, I bought a (different) house from an estate. The fellow who used to own it had tried to insulate between the eaves, but never finished the whole attic.
I am considering either
  • A) insulating between the eaves, as the previous owner started to do, and sacrificing the R-factor.
  • B) laying batt insulation on the floor. To the proper depth for my climate. I would also include proper roof venting in my plan. Right now. There are vents at both ends of the attic, that have been closed off by the previous owner. If I choose option B, I would re-open the vents, and likely install roof vents.
  • C) insulate both in the floor, and the eaves.
The only problem with option B is that I lose the storage space in the attic, which my wife isnít exactly thrilled about.
As you can see, I need input.
I have added pictures facing east, & west.
Signal Guy is offline   Reply With Quote
Old 02-23-2012, 12:31 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 898
Pictures are worth a thousand words in this case.
Old 02-23-2012, 12:36 PM   #3
Signal Guy's Avatar
I understand. I'm away from home at the moment, but will post pix of the attic as soon as possible.
Old 02-24-2012, 09:12 PM   #4
Rewards Points: 2,630
From my understanding, an attic should be either same temperature as outdoors (insulation on the floor) or same temperature as your living space (insulation on the roof). You seem to have half and half. Most people in cold climates find it a waste to try to heat their attic. From the photos, it looks about 4 feet tall. Thats not living space. What are you storing that needs to be kept warm? I would suggest the proper place for insulation is on an attic floor ( over-top of the vapor barrier and after sealing any air leaks). Hopefully you have vents under the soffits also.
SPS-1 is online now   Reply With Quote
Old 02-25-2012, 12:15 AM   #5
Signal Guy's Avatar
Thanks for your reply. First of all, you are correct; the height is about 4', give or take. The previous owner had tried to have it both ways, with insulation in the floor, and the ceiling.
I'm leaning towards insulating the floor. To get the required R value, I'll need to lay batt insulation above the floor joists. I'm thinking that I'll need to build up the joists at least in the section that I want to use for storage.
I don't know if I have soffit vents, or not. If I do, they aren't visible from outside. The house is a colonial, with contoured ceilings on the top floor. This makes it a bit difficult to check for soffit vents from the inside. But, I'll be spending a lot of time up there doing some re-wiring, and I will check more thoroughly.
Old 02-25-2012, 01:33 AM   #6
Rewards Points: 12,868
It would be best to go back and tap on your name and add where you live for better advice.
http://www.energystar.gov/index.cfm?...sulation_table
This is what you need for insulation.
For the new insulation to work, shingles to last longer, no ice dams. You need soffit vents and a ridge vent on the roof at the peak.
Total waist of time to have insulation on those gable ends.
Far more important to have proper insulation in that attic then have that small a room for storage.
There's no coller ties keeping the roof from spreading, and now where near enough insulation in that attic no matter where you live.
Old 02-25-2012, 09:31 AM   #7
Signal Guy's Avatar
Thank you for the reminder. Though the means to edit the profile is likely included in the Android app, I have yet to find it. So, I hadn't gotten around to doing it.
Guilty as charged on the collar ties. The house was built in '46, and the builders apparently didn't see a need.
Are they important enough to consider adding?
The insulation won't be done till after the re-wiring is completed. I have a lot of old wiring to deal with.
Old 02-25-2012, 09:56 AM   #8
Rewards Points: 898
I would just put off the wiring until the temps aren't quite as bad.
Here is what I would do:
  • Vacuum up all the old insulation to give yourself a nice clear work area.
  • Make all the wiring changes/updates without having to breath in the fiberglass and fuddle with it.
  • Air seal all the top plates, penetrations, etc prior to insulation
  • Make sure envelope and thermal barriers are complete, aligned, and share the same plane
  • Blow in cellulose to R-50+
Old 02-26-2012, 01:29 AM   #9
Registered User
Rewards Points: 4,924
"Guilty as charged on the collar ties. The house was built in '46, and the builders apparently didn't see a need.
Are they important enough to consider adding? "--------
You need collar ties if you live in a high wind area, tornado alley, Gulf Coast, etc. They are to keep the rafters from spreading at the ridge board, and blowing away; "Collar ties or ridge straps to resist wind uplift shall be connected in the upper third of the attic space in accordance with Table R602.3(1).
Collar ties shall be a minimum of 1-inch by 4-inch (25 mm by 102 mm) (nominal), spaced not more than 4 feet (1219 mm) on center." From: http://publicecodes.citation.com/ico...002_par018.htm
Another good read on removing them: http://www.finehomebuilding.com/how-...llar-ties.aspx
If you haven't seen any sign of mold, mildew, or ice dams over the years, you may not need soffit venting, especially as you are within 50 miles of a Great Lake (moisture source). Air sealing the attic, AND the crawlspace/basement to stop the "stack effect" is as important as ventilation; http://www.jlconline.com/cgi-local/v...170a32100a05c7
Think about an unvented roof assembly and control the indoor humidity: http://www.fpl.fs.fed.us/documnts/pdf2002/rose02a.pdf Notice the shingle temperatures...
As the house style won't accept soffit vents or roof edge vents: http://www.cor-a-vent.com/in-vent.cfm
you may want to go with a conditioned attic; http://www.buildingscience.com/docum...r-all-climates
Code has requirements for this, you are in Zone 5 and about 15 days of snow- http://publicecodes.citation.com/ico...006_par003.htm R-20 or 4" of foamboard, closed-cell, PLUS
this is code minimum (R-38) requirements, not "Energy Star" requirements, 6" of f.g. at R-19 would bring you to requirements.
Then you would be insulating in the rafter bays, not the attic floor at all, utilizing the space for mold-free storage with no fears. Close up the gable vents for good, reinstall the gable insulation after adding rigid f.b. first (equal to wall requirements).
Be aware, loading cellulose on 1/2" drywall at 2' on-center framing: http://www.energyguide.com/library/E...SubjectID=8375 Just check before you spray.
Gary
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 02:54 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 09:49 AM
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 08:21 AM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 08:08 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 03:10 PM
