Attic Insulation Direction - Insulation - DIY Chatroom Home Improvement Forum
Old 03-22-2012, 02:43 PM   #1
I just purchased my first single family home and I want to add insulation to the attic. It is a 57 year old house and has 3-4 inches of loose fill cellulose in the attic.
I'm going to add another layer of fiberglass insulation on top of it (without a moisture barrier). I've read online that if the existing insulation comes to the top of the rafters then the next layer should be laid perpendicular to the rafters. However, my existing insulation only comes about halfway up the board.
So my question is should the new insulation lay on top of the existing cellulose in the same direction, or should I go perpendicular to the rafters even though that would create a gap between the 2 layers?
Thanks in advance!
bmcnees16 is offline   Reply With Quote
Old 03-22-2012, 03:10 PM   #2
Thread killer
Rewards Points: 272
If you haven't done it already, get in there and seal all the air leaks. Then blow in more cellulose. Don't waste your money on fiberglass anything.
Canucker is offline   Reply With Quote
Old 03-22-2012, 04:40 PM   #3
Rewards Points: 1,092
agreed w/ canucker. batts are a poor choice, esp if left exposed to air currents in attics. air sealing is critical; any penetration should be goo'ed or spray foamed.
Old 03-23-2012, 12:51 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,972
Air seal and just blow more cellulose.
Leave the batts out.
Tags
attic , insulation
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 02:54 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 09:49 AM
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 08:21 AM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 08:08 PM
Adding attic insulation pomelo Building & Construction 3 10-22-2009 06:19 PM
