Attic Insulation - Baffles, Air Flow Questions - Insulation - DIY Chatroom Home Improvement Forum
Old 03-22-2012, 03:55 PM   #1
Rewards Points: 53
I am looking to blow in insulation (green fiber) in my 1,300 SQ FT attic. I’m a Zone 5 here in suburbs of Chicago, IL. The house was built in ’75 and I’ve lived here almost 2 years.
Until last week, if I heard “batts and attic”, I would’ve called an exterminator, so I’m very new to all this.
I have already sealed the attic and am looking to install the baffles and cover any electrical items in the next few days before I blow the insulation in. The attic is very challenging to get into places around the edges, because of existing insulation, narrow passage and most importantly the nails poking through the roof.
I have three questions:
1.) I have 10 soffit vents but no way to know if they’re open. I can’t access them from the attic and can’t get them from a window. I do NOT have a ridge vent, but do have an attic fan. I already installed the baffles on one side of the roof, but do I need them since there is no ridge vent? I’d prefer not to take them down again, but would if that’s the right thing to do
2.) There are significant “gaps” between the attic floor and the walls. I’m assuming these are “soffits” and should NOT be filled with insulation. In the green circle, it's actually space before it gets to the board behind it.
<BR><BR>
3.) Do I need to cover these electrical boxes with sheet metal?
Many thanks
majch is offline   Reply With Quote
Old 03-22-2012, 04:32 PM   #2
Rewards Points: 1,092
Good move to insulate w/ cellulose. You absolutely need ventilation, about 1 sqr ft per 150' sf of roof (some folks say up to 300 sf). More vents on the bottom than top is best. Greenbuildingadvisor.com just had a blog (or reference to it in another one) about this. Keep insul away from any boxes, fan, vents, yes; at least 2" of air over insul where it meets the edges of the roof. Lights that are covered should be approved for such, not just any light; check w/ local elect company or building dept.
Old 03-22-2012, 06:34 PM   #3
Rewards Points: 13,458
If it was my house I'd get rid of the gable vent and powered vent and add a ridge vent.
Then the whole roof gets vented not just the ends or a circle where the vent is.
Old 03-22-2012, 07:15 PM   #4
Rewards Points: 53
Do i need to place sheet metal around the electrical box to protect it?
Old 03-22-2012, 07:22 PM   #5
Joe: That is a good point. The power vent may cause a negative pressure in your attic, which tends to draw air from the conditioned space into the attic. That is not good, as that losses heat and brings moisture w/ it. That was mentioned the the gba blog I mentioned, and why more vent on the sides is better than the top, if you have any on top. It still seems, intuitively, that the negative pressure would be tough to get, with lots of soffit vents, but that is what apparently happens. Check locally for what is required over lights. There may be particular specs for material and distance from light, as well as wattage, etc.
Old 03-22-2012, 07:54 PM   #6
Registered User
Rewards Points: 5,492
If the gap next to the rafter blocking has a screened vent, or continuous screened vent, the baffles need to protect that gap from insulation. Your baffles are good for the roof sheathing to direct soffit (intake) air up, but are lacking the (lower) wall insulation-blocking part: http://www.bergerbuildingproducts.co...sAccuvent.html
See how those block the incoming air from the insulation directly over the wall? You could add the "Windblocker" from Lowe's to compensate...
More heat is lost at the exterior wall because of minimal insulation (low height restriction) and incoming soffit air wind-washing your hard-earned work/money.
Recessed can lights only need to have a box, and only non-rated; IC = insulation contact.
Per Electrical Code, you need to protect any wires within 6' of the downstairs access, so a future H.O. won't step on the wires on the ceiling joists.
If you decide to leave any attic flooring in place and blow cellulose over it, check on it periodically for mold under the sheeting because the drying air flow will be blocked by the new cellulose. Elevated cat-walks are nice. May need to build an insulation box for the drop-down stairs and store the window screens elsewhere. If you haven't had attic moisture problems- mold, rusty nail ends, etc., I would leave the ventilation system, as-is. Powered exhaust fans do pull air from the closest source, your gables, which will help move the stagnate air, and draw moisture from the convective loops at each side of the ridge.
Gary
Old 03-23-2012, 09:27 AM   #7
Rewards Points: 53
Thanks for all the replies. It’s clear I have an issue in that the baffles I installed have left a gap and are lacking the (lower) wall insulation-blocking part. I should’ve installed the part that GBR recommended. Tearing down 40 and re-installing them isn’t the best option for me mentally, so:
I think I have 2 options:
1.) Install an ado product that will block the air
2.) Put batt fiberglass insulation to fill the gap so that my blown insulation doesn’t cover the soffit
#2 would be easier for me, but my understanding is that air would still get in. I have searched high and low (amazon, HD, Lowe, internet) and no one has any ADO product in stock. Anyone have any feedback on what I should do?
Old 03-24-2012, 11:04 PM   #8
Registered User
Install rigid foam board, foil-faced, on end, over the wall. Each one cut longer to fill-in solid when side-by-side. They would need to be can foamed at the top as each baffle is variable in the rafter/joist space. Or, just put some f.g. batt in a plastic bag and shove, though the area directly over the plate would not meet minimum R-value and lose R from compressing. Either way- over the exterior wall is the most heat loss (ice dams) and that area is the most wind-washed: http://books.google.com/books?id=3kL...201991&f=false
http://www.arc.thermaldr.com/res_pg_3.htm
Gary
Attic Project – Venting and Insulation spaceboy Insulation 3 09-08-2011 09:54 AM
Attic Insulation tim1218 Insulation 4 09-07-2011 10:18 AM
Attic insulation bids and soffit vents-need input nolamar Insulation 7 05-14-2011 10:04 PM
Attic Insulation paige2 General DIY Discussions 21 03-16-2011 10:35 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
