Attic Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 05-03-2014, 11:24 AM   #1
Attic insulation
I've been reading and reading and reading. I have more questions than answers but no one will accuse me of not researching. I'm ''cursed" by having my bedroom under the attic and over the garage. As you might imagine, it's freezing. My first intended project is the attic. Here are some pictures and I will refer to them as I make my questions.
Attic insulation-attic2.jpg   Attic insulation-attic3.jpg   Attic insulation-attic6.jpg   Attic insulation-attic5.jpg
simagic is offline   Reply With Quote
Old 05-03-2014, 03:11 PM   #2
Rewards Points: 6,652
The floor between the garage & room should have Spray foam in that area. As for the attic. Blown insulation is best for keeping any heat from leaking up there during the Winter time.
But with that angle. You are better off using a Spray insulation. It does appear that Batt is too tightly packed in.
Old 05-03-2014, 03:15 PM   #3
Yes, thank you. That's why i said I was going to blow in the cellulose. It's the issues mentioned ( particularly about the space around the baffles) that I was most inquiring about.
Old 05-03-2014, 05:16 PM   #4
You cannot blow in insulation, due to the angle of that wall. Also you need breathing area between the ceiling of the garage and the floor of the room above.
The Following User Says Thank You to gregzoll For This Useful Post:
Windows on Wash (05-03-2014)
Old 05-03-2014, 06:00 PM   #5
There appears to be 2 posts (posted by me). One is incomplete of all my info. Please see my post with the time of posting being 3:55pm for a full description of what I'm talking about. That should clear up what I'm talking about. Not talking about anything to do with the garage right now. These are not pictures of a garage. This is the attic. You will see upon reading that post
Old 05-03-2014, 06:17 PM   #6
See my posts regarding the attic. There is nothing more to state.
Can/should I add insulation underneath stationary stairs to my attic? Bitruder Insulation 3 12-29-2012 12:04 AM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 02:54 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 09:49 AM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 08:08 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 03:10 PM
