Attic Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 12-04-2013, 05:27 PM   #1
Attic Insulation
So my house does not have an eve overhang like most newer houses and just has an angled fascia board. When I replaced the fascia I also added the vents you can see in the photo, these vents are not in every bay (not sure if they need to be).
So now i'm on to fixing the insulation in the attic as there is basically none. Being as the above vents are not in every bay should I still put baffles in each bay or just the ones that have the vents?
Also rather than baffles in the bay could I just cut a piece of plywood and attack it to the underside of the rafters and push the insulation up to that?
Thanks,
dabeast is offline   Reply With Quote
Old 12-05-2013, 01:03 AM   #2
Registered User
Rewards Points: 4,888
Figure the NFVA using the tables/math; http://www.airvent.com/homeowner/pro...it-specs.shtml
Figure the intakes (should be a NFVA # on them: http://www.lomanco.com/intakemain.html
Use a baffle in every bay out of foam board; http://www.buildingscience.com/docum...n-roof-venting
Add fb stacked on the ext. wall top plate after air sealing entire attic; http://www.google.com/url?sa=t&sourc...cMUmwWATQw&cad
Gary
Old 12-05-2013, 12:07 PM   #3
Gary
Not sure what you mean by that and also don't understand from the link.
Thanks,
Old 12-05-2013, 03:35 PM   #4
Registered User
Sorry, foam board laid flat and stacked to get minimum R-value required for your Zone (R-49) due to low clearance between roof sheathing/drywall. If unable to get full R-value per code for ceiling, at least get minimum (per code) for walls (R-20) to use up there. http://energycode.pnl.gov/EnergyCode...?state=Montana
The link was on air sealing the attic, did it not work?
Gary
PS. You may want to add a handrail and close off the risers on your front steps, to make min. code for liability/safety for visitors; http://publicecodes.cyberregs.com/ic...2_3_par104.htm
http://publicecodes.cyberregs.com/ic...2_3_par108.htm
May also need a landing/guardrails, check with local AHJ; http://publicecodes.cyberregs.com/ic...2_3_par109.htm as you may be under that part of the IRC; http://www.reedconstructiondata.com/...codes/montana/
Never-mind.... on closer look it appears those are temporary stairs... lol.
Old 12-05-2013, 03:39 PM   #5
Yea there is a deck there now. That picture was taken last fall after the siding was done.
Old 12-06-2013, 08:53 PM   #6
Registered User
I realized that, thanks! Any other questions?
Gary
Old 12-06-2013, 10:30 PM   #7
Solutions (handyman)
Rewards Points: 362
vents
I see in the picture that you have venting in the soffits, but is there any on the roof? You need the folw of air to be effective. As to insulation,every "bay" should be blocked where the wall and roof meet, ... leaving about 1" gap for air. Consider blow-in insulation, you can get better overall coverage and add to it, if need be, at a future time.
Mark Harvey is offline   Reply With Quote
Old 12-07-2013, 07:20 AM   #8
Rewards Points: 140
i used fanfoil for my baffles. cut it to fit each bay. cut it to let it go on top of the top plate. staple on to underside of rafters. at the top plate, xps pieces with spray foam to make the ff go up to about 1" from the roof sheathing.
Fix'n it is offline   Reply With Quote
Old 12-07-2013, 07:23 AM   #9
Rewards Points: 140
here is a good pic ( i ran out of xps pieces at this point).
Old 12-09-2013, 10:31 AM   #10
All the roof vents are on the back of the house.
Old 12-09-2013, 03:36 PM   #11
Rewards Points: 362
ceiling insulation
Hi Montana, It's looking good. Here is a mental picture. Think of an attic as a room above your living area. Underneath is usually covered with something like a floor (ceiling drywall or other material) then the walls (your roof). The bottom should be well insulated to keep the heat in the living area ... in the living area. above that, you want air circulation from the soffits up and out through your vents. Personally I prefer a ridge vent over other types. (A ridge vent runs the entire lenght of your roof line and literally vents the total space evenly). The same concept applies if the roof is to have insulation attached to the trusses, you still need that air flow from the soffits up and out, that's why there is a gap above the solid insulation and the wood sheathing (your roof). Hope his helps. Mark
Can/should I add insulation underneath stationary stairs to my attic? Bitruder Insulation 3 12-29-2012 12:04 AM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 02:54 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 09:49 AM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 08:08 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 03:10 PM
