Attic Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 02-07-2013, 01:00 PM   #1
Rewards Points: 1,046
Attic insulation
Hello
I received my heat bill for January, and itís quite high
My furnace is old, and on top of it I guess my house needs more insulation in the attic. That last point might be easier to fix right away, and cost less than replacing the furnace
The section of my roof looks like that (see picture)
I know the additional insulation material must not block the vent, and attic baffles should be installed (I will verify if I already have some)
But if there is no baffle already in place, I guess I donít need them on the left side since I wonít insulate the portion over the porch, so there is no risk to block the soffit vent, right?
Do you see any problem not insulating over the porch?
french_guy is offline   Reply With Quote
Old 02-07-2013, 01:12 PM   #2
Rewards Points: 626
No there is no problem with that I would just put some thing to make sure if you go with loose fill that it does not just spill over. I would bring your insulation up to min R-49 and R-60 is the best and does not cost that much more.
Nailbags is offline   Reply With Quote
Old 02-07-2013, 02:05 PM   #3
Yeah, I am in Michigan, greater Detroit area.....And it's cold right now
So I guess R-60 is the way to go
Old 02-09-2013, 11:43 PM   #4
Registered User
Rewards Points: 5,204
Before you add any, check if all the wiring/plumbing holes/chases are sealed from the walls below. Air-seal the crawlspace/basement holes in plates/sub-floor there also. This will help stop the "stack effect" and loss of heat you already paid for; http://www.wag-aic.org/1999/WAG_99_baker.pdf
http://www.google.com/url?sa=t&sourc...wWATQw&cad=rja
Wind can push drafts...http://www.greenbuildingadvisor.com/...-through-house
Canned foam savings; http://www.ornl.gov/sci/buildings/20...s/80_Bibee.pdf
No ice dams, check your ventilation; http://www.brainerdhomeinspection.com/roofve~1.pdf
Gary
Can/should I add insulation underneath stationary stairs to my attic? Bitruder Insulation 3 12-29-2012 12:04 AM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 02:54 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 09:49 AM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 08:08 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 03:10 PM
