-   Insulation (http://www.diychatroom.com/f103/)
-   -   Attic insulation (http://www.diychatroom.com/f103/attic-insulation-171293/)
french_guy 02-07-2013 01:00 PM
Attic insulation
1 Attachment(s)
Hello
I received my heat bill for January, and itís quite high
My furnace is old, and on top of it I guess my house needs more insulation in the attic. That last point might be easier to fix right away, and cost less than replacing the furnace
The section of my roof looks like that (see picture)
I know the additional insulation material must not block the vent, and attic baffles should be installed (I will verify if I already have some)
But if there is no baffle already in place, I guess I donít need them on the left side since I wonít insulate the portion over the porch, so there is no risk to block the soffit vent, right?
Do you see any problem not insulating over the porch?
Nailbags 02-07-2013 01:12 PM
No there is no problem with that I would just put some thing to make sure if you go with loose fill that it does not just spill over. I would bring your insulation up to min R-49 and R-60 is the best and does not cost that much more.
french_guy 02-07-2013 02:05 PM
Yeah, I am in Michigan, greater Detroit area.....And it's cold right now
So I guess R-60 is the way to go
Gary in WA 02-09-2013 11:43 PM
Before you add any, check if all the wiring/plumbing holes/chases are sealed from the walls below. Air-seal the crawlspace/basement holes in plates/sub-floor there also. This will help stop the "stack effect" and loss of heat you already paid for; http://www.wag-aic.org/1999/WAG_99_baker.pdf
http://www.google.com/url?sa=t&sourc...wWATQw&cad=rja
Wind can push drafts...http://www.greenbuildingadvisor.com/...-through-house
Canned foam savings; http://www.ornl.gov/sci/buildings/20...s/80_Bibee.pdf
No ice dams, check your ventilation; http://www.brainerdhomeinspection.com/roofve~1.pdf
Gary
