Attic Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 08-13-2012, 10:34 AM   #1
Attic Insulation
I have a similar problem living in So Cal and my house was built about 30 years ago + or - and lately the heat has been unbearable! (110* average last 3 days) I have recently installed 2 gable fans
I have adequate ventilation and there's the standard tract home insulation but it's just not enough.
My upstairs is 10* to 15* hotter then downtairs
Would I benefit from installing fiberglass insulation between the roof rafters?
the attic has a finished floor with insulation between the floor, but it is still crazy hot upstairs
murphdog is offline   Reply With Quote
Old 08-13-2012, 10:57 AM   #2
AGWhitehouse's Avatar
Heat does rise, so it's only natural for the second floor to be hotter than the first. Insulation at the rafters won't really help much considering the space is ventilated.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 08-13-2012, 04:10 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,586
What do you have in terms of insulation up there?
Radiant barrier have some (albeit very little) application value. This might be one of them but as AGW said, you are going to note some temperature difference regardless.
Old 08-15-2012, 11:42 PM   #4
Registered User
Rewards Points: 5,514
Hot air does rise. It's doable, but can get dicey; http://www.buildingscience.com/docum...ifornia-attics
Air seal the ceiling plane first.
Gary
Old 08-16-2012, 11:12 AM   #5
So page 18 essentially shows no real gain from insulating the roof plane while leaving the attic space ventilated. You'll spend alot of $$ and time doing the work for negligable gains...
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 08:49 AM
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 07:21 AM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 07:08 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
