Attic Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 09:00 AM   #1
attic insulation
Can flat pink insulation be put over top of blown insulation that is already in my attic?
Jackiepottier is offline   Reply With Quote
Old 01-08-2012, 09:52 AM   #2
Rewards Points: 1,192
Unfaced.
bobelectric is offline   Reply With Quote
Old 01-08-2012, 09:58 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I don't think that's a very good idea. You really need to have more blown in. How deep is what's already up there?
They usually blow in about R-30's worth.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-08-2012, 10:29 AM   #4
Ironlight's Avatar
Why do you think it's not a very good idea?
Ironlight is offline   Reply With Quote
Old 01-08-2012, 10:41 AM   #5
Disabled wood vet
titanoman's Avatar
I'm not sure, which is why I said "I don't think". Isn't it supposed to be fluffy, not compressed?
I really don't know what I'm talking about.
The only thing I am sure of about insulation is that most of it is itchy and gets in your eyes. I wouldn't do insulation for $20/hr, though I've had to handle it and be around it a million times.
Old 01-08-2012, 01:02 PM   #6
Solutions (handyman)
Rewards Points: 364
Attic insulation
I would not put batt insulation on top of blown in ... because it would compress the blown in and it would lose ot R factor. Here in the north the insulation companies are suggesting R-50 as the norm. May be over-kill but if it works as it should, payback in heat savings is worth it.
Mark Harvey is offline   Reply With Quote
Old 01-08-2012, 06:51 PM   #7
Registered User
Rewards Points: 5,516
If the blown-in is fiberglass and the batt insulation is fiberglass, you will be fine, they both weigh the same (0.04) per square foot 1" thick; http://www.bc.com/dms/wood/ewp/3_Gui...0Materials.pdf
You will be increasing the density, which is a good thing;The "biggest loser" in fiberglass insulation....
The R-value vs. the cost of insulation has its limits; http://www.enersavesystems.com/pdf/E...Insulation.pdf
Air-seal the attic first to utilize the money spent on the added insulation; http://www.jlconline.com/cgi-local/v...170a32100a05c7
How to DIY: http://www.google.com/url?sa=t&sourc...wWATQw&cad=rja
Gary
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 08:49 AM
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 07:21 AM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 07:08 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
