Attic Insulation - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-22-2011, 04:34 PM   #16
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
I will be adding to what is already there on the edges, and running it perpendicular to the rafters
Barry J is offline   Reply With Quote
Old 11-23-2011, 12:22 AM   #17
Registered User
Rewards Points: 526
I'd pull the f.g. to use farther back from the low-slope. Here I would use rigid foam board (after air sealing), for 2' or more. Stack them up, staggering the joints against air pathways. http://bct.eco.umass.edu/publication...o-save-energy/
Problem is the required R-value in the limited space, as you well know, hitting your head often. I don't envy you.........
Gary
Old 11-23-2011, 12:49 AM   #18
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,280
Air loss and low R-Value at the eaves are the two biggest issues that contribute to ice damns and snow melt.
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 08:49 AM
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 07:21 AM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 07:08 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
