Attic Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 10-26-2011, 01:07 PM   #1
Rewards Points: 20
Attic Insulation
My wife and I recently purchased a 2 story house and we are noticing a rather large temperature difference between the first and second story. I took a peek up in the attic and noticed that there is loose insualtion there already and the previous owners were kind enough to leave kraft faced R-19 insulation batts still packaged when they moved out. They started the project but never finished. My question is A) is faced the better option to unfaced for what I am looking to finish and B) if faced is fine does the facing go up or down? The way they had installed half the attic is with the facing up, but everything I have read about faced insulation is that the facing should go towards the house not towards the roof. Thank you for your help.
btadler is offline   Reply With Quote
Old 10-26-2011, 01:39 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 848
Depends on the location of the home (i.e. region of the country/world).
In most applications, vapor barriers are not required and used improperly.
Old 10-26-2011, 02:05 PM   #3
Rewards Points: 20
We live in Madison Wisconsin. I don't necessarily need the vapor barrier but I already have it from the previous owners. If it is recommended not to have then I will buy new insulation.
Old 10-28-2011, 11:41 AM   #4
Rewards Points: 848
Air seal the attic first and it won't much matter which side the vapor barrier is on.
No need to throw them out.
http://www.youtube.com/watch?v=8n3QC...eature=related
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 02:54 PM
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 08:21 AM
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 08:08 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 03:10 PM
Remove old attic insulation and critter mess? merlanvp Building & Construction 6 07-27-2010 05:36 PM
