Attic Insulation ? - Insulation - DIY Chatroom Home Improvement Forum
Old 09-19-2011, 07:08 PM   #1
Attic Insulation ?
I have one of those walk up attics that doesn't have insullation, but would make a cozy room if insulated and finished. What's the easiest way to insulate an attic and what products are the least toxic to work with?
ILOVECAKE is offline   Reply With Quote
Old 09-19-2011, 07:28 PM   #2
Rewards Points: 370
depends on what your space above it and in the walls is as well as budgeting. Personally, I would look at closed cell spray foam, and if your a bit budget tight, you can "flash and batt" which is a bit of closed cell spray foam, and a bit of batts, although the cost savings vs given up insulation isn't worth it to me.
you can diy if you want, there are kits online for it which I'm sure a few people will link to in a minute or 2, but yea, the space you have to fit the insulation is going to be the big question. I think you want 2x6's at least on the exterior and probably 8 to 10 inches on the roof, although again someone will come along and tell you what you need for a final insulation value on those.
if you poke around on here...
http://www.buildingscience.com/
you can find the recommended insulation value for your area.
MLMIB is offline   Reply With Quote
The Following User Says Thank You to MLMIB For This Useful Post:
ILOVECAKE (09-20-2011)
Old 09-19-2011, 11:33 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,092
Totally depends on how you plan to finish it.
Spray foam is great in both application (i.e. roof rafters/trusses and underside of roof decks) but is expensive.
What are you planning on doing?
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 09-20-2011, 11:32 AM   #4
Post
I have no idea. It was just a thought because it seems easy and will add value to the house for sure. I need to sell this house, that's why i bought it. Right now sales in this area are S L O W and just sitting there. Normally, you never see for sale signs on a property because they are listed and under contract within a week of being on the market. This summer it's been terrible and I'm not going to sell it now, but I also can't live here anymore either. It's being rented on the 1st, but I'm thinking that maybe I can start a project up there. I'm blocking off access to the tenants, all my sh** is up there.
The area is pretty large and it's just roof rafters that are exposed. It's like if your not careful, you can end up bumping a nail through your skull (if your lucky)
Where are the trusses?
Old 09-21-2011, 10:03 AM   #5
Truss is another type of roof framing vs. rafter.
You need to first figure out what you want to do and that will somewhat dictate what the most appropriate way to insulate the space.
Most everything you can do with spray foam can be duplicated in more common and less expensive insulation materials.
Old 09-21-2011, 04:07 PM   #6
Registered User
Rewards Points: 5,492
I find out if the space is legal and structural first. Is there a required egress window? http://docs.google.com/viewer?a=v&q=...33otStRi7Aff7g
Are the attic floor joists sized for a living space conversion? http://publicecodes.citation.com/ico...002_par017.htm
Heat, light and ventilation, smoke alarm, egress stairs, headroom (sounds good), etc.
http://docs.google.com/viewer?a=v&q=...1txlzU01V4JQIg
Drawings, permits, inspections...
Then insulation.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
ILOVECAKE (09-22-2011)
Old 09-22-2011, 12:30 AM   #7
Then insulation.
Gary
Very Good! I like your thoroughness. Thank you
Old 09-22-2011, 12:57 AM   #8
Wink
Pictures answer many questions So here is my attic.............
Isnt it a cool space with potential to be a cute cozy area? Sorry about all the junk in the way. At least now you have an idea of what it looks like.
Attic Insulation ?-imag0924.jpg   Attic Insulation ?-imag0923.jpg   Attic Insulation ?-imag0920.jpg   Attic Insulation ?-imag0919.jpg
The Following User Says Thank You to ILOVECAKE For This Useful Post:
Gary in WA (09-25-2011)
Old 09-25-2011, 09:27 PM   #9
Registered User
I'd install a smoke alarm up there for the extension cord/table lamp on the floor.
Gary
Old 10-12-2011, 10:17 PM   #10
Rewards Points: 956
dude that's plenty of space to build a room!
federer is offline   Reply With Quote
Tags
attic insulation , easy insulation , non toxic insulation , spray insulation
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
Attic Insulation gruntman Roofing/Siding 12 12-04-2010 09:01 PM
Remove old attic insulation and critter mess? merlanvp Building & Construction 6 07-27-2010 04:36 PM
Attic insulation and soffit venting zacker Building & Construction 1 07-15-2010 10:17 PM
