From Attic, Insulate Short Open Wall Cavity Above Window? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-10-2014, 08:40 AM   #1
From attic, insulate short open wall cavity above window?
I'm insulating the attic of our 1921 home, being careful to keep the rafters clear where they come down to meet the walls for ventilation. However, at a gabled area in the attic, where there is an attic fan, and where the rafters don't come down, there is a shorter span where wall studs extend up from the window bay in the floor below, and that wall cavity is just open up to the point where the attic fan sits. Can I fill that small area with loose-fill insulation, or do I need to leave it open for ventilation?
Thank you for any help.
RobbM is offline   Reply With Quote
Old 02-10-2014, 08:43 AM   #2
Rewards Points: 13,724
Got a picture?
Old 02-10-2014, 08:52 AM   #3
From attic, insulate short open wall cavity above window?-image-1274889614.jpg
I pulled back the loose fill but my camera isn't liking the lighting... Basically where you see the main line of insulation, the floor joists go another few inches, and the open area then drops into a maybe 2-ft deep wall cavity. Obviously it's not a huge area to insulate but it's something; I just don't want to cause moisture problems.
Old 02-10-2014, 08:53 AM   #4
"deep" as in vertically
Old 02-10-2014, 06:44 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,662
Insulation looks a bit shinny in the back.
Make sure it is not vermiculite!!!
Old 02-10-2014, 08:02 PM   #6
Ha, no, but I'm glad you're looking out for me. ;-) you might be looking at an old flakey paint job, which come to think of it, is probably lead-based. If it's not one thing it's another.
Old 02-10-2014, 10:30 PM   #7
Registered User
Rewards Points: 5,514
Is there brick veneer or sheathing, if an outside wall? Location?
Gary
PS. Welcome to the forums!
Old 02-11-2014, 06:00 AM   #8
Thanks for the welcome- yah, it's an exterior wall with brick veneer. If it's like the rest of the house, there's that wall cavity with plaster/lathe on one side, studs, then 1x8s wrapped in old tar paper; then another air cavity, then brick veneer.
Old 02-11-2014, 06:04 AM   #9
From attic, insulate short open wall cavity above window?-image-4017461571.jpg
Maybe this is a better picture overall. I'm working under the attic fan
Old 02-13-2014, 11:21 AM   #10
That beast can move some air I bet.
Old 02-14-2014, 08:58 AM   #11
It's not a pooch! Can't say we use it all that much, though. Mostly because I don't like leaving windows downstairs at night.
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Updating Timber & Balloon Framed Home (LONG POST) Pittsville Building & Construction 13 05-29-2013 12:15 PM
Insulating attic wall shared with living space BlueBSH Insulation 2 07-12-2012 11:04 PM
How to insulate 1' concrete wall that meets 8' studded wall Truth Insulation 7 01-16-2012 08:14 PM
Want to install larger window in basement wall andrewcocke Remodeling 8 02-24-2008 10:51 PM
