Attic Insualtion - Insulation - DIY Chatroom Home Improvement Forum
Old 09-26-2011, 04:42 PM   #1
Attic Insualtion
My attic space has the isnualtion installed incorrectly. Kraft paper up and it is dteroriated. I want to repalce it but, not sure if I need to put a vapor barrier down or just replace the isnualtion with new with the kraft paper and install it face down. Attic is not heated. Also how do you get around the metal strappings that are used for the joints?
madisonsquare is offline   Reply With Quote
Old 09-26-2011, 05:00 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,820
Where is the home located?
Your painted drywall ceiling is probably just as much of a vapor barrier than unsealed Kraft paper.
Old 09-26-2011, 07:25 PM   #3
Hi Thanks for the reply. I am located on Long Ilsand in New York
Old 09-27-2011, 01:18 AM   #4
No vapor barrier is required.
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 04:07 PM
Raccoons in the attic electricpete Pest Control 17 05-12-2011 05:02 AM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 05:17 PM
Attic fan options P550 Roofing/Siding 1 08-22-2010 01:47 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
