Attic Fan Louvers- Interior DIY - Insulation - DIY Chatroom Home Improvement Forum
Old 01-07-2017, 02:30 PM   #1
MLD
Rewards Points: 4
Question
Attic Fan Louvers- interior DIY
How to make my own interior ceiling attic fan cover?
MLD is offline   Reply With Quote
Old 01-07-2017, 02:31 PM   #2
MLD
Rewards Points: 4
Re: Attic Fan Louvers- interior DIY
Anyone got a tip on how to make my own ceiling mounted cover for an attic fan?
Old 01-07-2017, 03:49 PM   #3
Rewards Points: 1,470
So,
What I did was a bit unusual but it worked.
I used an old squirrel cage that I ad from when the air handler on my HVAC system was replaced.
The air return was attached to a plenum in the ceiling which in turn had a soft duct run that went to the squirrel cage.
Mounted a switch on the wall and off to the races.
In the winter, I simply installed a 3/4" foam board where the filter would normally go.
Works great.
ktkelly is offline   Reply With Quote
Old 01-07-2017, 07:29 PM   #4
Rewards Points: 1,242
I need to build one too. I'm not a good designer but an excellent copier so would you go first?
That's how I got to the 6th grade.
Tags
attic fan , ceiling , cover , diy , insulation
Insulating an Attic - Spray Foam in the Rafters v. Cellulose on the Floor esteve999 Insulation 5 12-13-2014 10:29 AM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
