Attic (cross)ventilation - pre-insulation Qs
I could really use some help in determining where/how to improve my attic ventilation, before I even dare to invest in new insulation. For all my reading on ideal ventilation scenarios (balanced soffit/ridge systems), I cannot begin to visualize the current / desired airflow patterns for the shape and configuration of my attic.
Disclaimer: As will soon become evident, I am not at all a seasoned DIYer - this would be my first project of any consequence. Air-sealing and insulating an attic is probably a "weekend project" to most of you, but it seems like a herculean task to me!
http://i1338.photobucket.com/albums/...pse8d56b47.jpg
Bathroom exhaust: Now vented through soffit. •• Bad idea. Moisture will just float back into the attic.
Vapor retarder: If 1/150 NFVA ratio (or other requirement) could be achieved within current constraints, would there be a need for Type II/III vapor retarder (e.g., faced FB batts) beyond ceiling paint? Or would it be acceptable to just air-seal then blow in cellulose to desired R value? •• If you can air seal real well, the vb is not necessary. However, if you are in a cold climate a vb may not hurt. Air sealing is more important that a vapor barrier; make sure the vapor barrier, if used, is sealed tight, too. |
Thanks for taking a look, jklingel. You are indeed correct about not needing a vapor barrier in my climate - I knew I had seen that somewhere, and I since found the link again.
Bathroom exhaust - such was my fear. This was the PO's fix in response to problems raised during the inspection (i.e., when the bathroom exhausted directly into the attic) which, as far as I can tell, is strictly "correct" (the duct does run to the outside, after all), although far from satisfactory. Looks like we have traded one problem for another, and will have to trade it for a risk (new perforation through the roof). |
http://publicecodes.cyberregs.com/ic..._12_par004.htm
Pitch does not figure in NFVA, only floor area; http://www.airvent.com/homeowner/pro...it-specs.shtml Gables are exhaust vents unless the wind is directly at one, pp.9; http://archive.nrc-cnrc.gc.ca/obj/ir...s/bpn/57_e.pdf Gable vents require way more area than built, scroll backward to chapter on pp. 603, read esp. 605, 616; http://books.google.com/books?id=Z8a...0vents&f=false Notice mention of center soffit vents/, gable/soffit, and placement of soffit continuous venting... More on gables as exhaust; http://en.allexperts.com/q/Roofing-1...able-Vents.htm http://www.finehomebuilding.com/desi...ble-vents.aspx Run the bath exhaust to the gable end rather than through the roof, IMO. Gary |
Gary, thanks for your response and links. It was in fact links that you provided in response to other posters that had me rethinking ventilation. (If I am interpreting them incorrectly, the fault is all mine.)
First, I must apologize for an inappropriate choice of words that seemed to imply that I had gable vents. I do not - the soffits under the gables do have vents. I believe "rake" is the word I should have used for those, not "eave". Anyway, they are visible on the N, S (5' high) and E (3') sides. I find very little information online regarding rake soffit vents - is this because: a) they have another name unknown to me b) they are treated like another type of vent, same considerations apply (gable or soffit vents? a bit of both depending on height? 3' seems like the magic number for gable vents...) c) really shouldn't be there (I see recommendations for sealing them to avoid rain penetration, but I have a hard time imagining this would occur with a 2' overhang?). The various texts you link confirm my suspicion that replacing the existing vents/panels by a continuous strip near the fascia would address most of my concerns. If the higher "rake soffit" portions qualify as exhaust vents, I would end up with more ventilation than strictly necessary; if they count as intake (or nothing much), I'd meet the 1/150 rule of thumb (already pretty close) for non-balanced systems. I would indeed feel better about running the bathroom exhaust through the N gable than through the roof, good point! Would that require sealing off the rake soffit vents in the vicinity? (Again, same hesitation on my end - are those considered intake or exhaust?) To be honest, at this point I am seriously considering enlisting professional help for both ventilation and insulation - that's a lot of insulation that could potentially be wasted if I make a bad judgment call. I also question my ability to crawl to and reach all the nooks and crannies of such a constrained space (not to mention whether R-50/60 is even reasonable in such a case). ... that said, I still value any input that might help me have an informed conversation with a contractor, convince my husband that one is needed (!) or minimize my chances of failure if I lose the latter argument :) |
Usually the gable overhang (on the rake) is closed off from the main roof, so venting those would not be figured in the balanced system for the house attic. If you check them from inside the attic, the truss/rafter framing or the gable end wall sheathing extends to the top, blocking any air-flow there- intake or exhaust. Builders typically soffit vent the rakes against rot/moisture accumulating in them. You are correct with no vapor barrier/retarder for your location: http://www.buildingscience.com/docum...on?full_view=1
Your Zone 5 requires minimum R-38 in the ceiling; http://www.reedconstructiondata.com/.../pennsylvania/ 2009 IECC; http://publicecodes.cyberregs.com/ic...9_4_par004.htm And more specific; http://publicecodes.cyberregs.com/ic...9_4_par008.htm Air-seal first, as you said;http://www.google.com/url?sa=t&sourc...wWATQw&cad=rja Weight the value vs. cost; http://www.enersavesystems.com/pdf/E...Insulation.pdf You may want to use some housewrap over blown-in fiberglass to stop convective loops and wind-washing near the intakes. Cellulose is fine, stand-alone. You could seal off the middle gable vents from the bath exhaust, if the aren't already (punched ones clog from air-born dust), lol. The venting may be adequate as is (esp. if no ice dams or mildew/mold on rafters), though adding insulation sometimes creates problems; http://www.fpl.fs.fed.us/documnts/pdf1999/tenwo99a.pdf http://books.google.com/books?id=_pc...page&q&f=false But, if you do have ice dams; http://www.brainerdhomeinspection.com/roofve~1.pdf Gary |
Here's a link that may help you understand more about attic ventilation.
http://www.buildingscience.com/searc...=attic+venting |
If you read the building science site you will discover that attic ventilation is not required or necessary contrary to what others here believe and preach.
I read the Building Science report about attic venting and I must have missed the part where it said venting is not necessary. :confused1: |
As there is no more ductwork in the attic (" I would be happy to provide pictures or additional details upon request, although the 5/12 portion of the attic is mostly blocked off from access/view by utterly useless ductwork (to be removed!) ")AND the roof design is fairly simple as pictured, you want to stick with a "vented" attic as BSC recommends; "Vented attic/roof designs have the advantage of a long, proven historical track-record. However, they work best with airtight ceiling/attic interfaces and where ductwork and air handlers are not located within attic spaces. The increase in the use of complex roof shapes and cathedral ceilings has resulted in problems with vented roofs." From; http://www.buildingscience.com/docum...ttic%20venting
Gary |
| All times are GMT -4. The time now is 06:10 AM. |
