Attic Baffles And Adding Insulation...HELP!!! - Insulation - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 01:23 PM   #1
Ok I have R30 in my attic and have decided to add an additional r30 for a total of r60. I noticed that only the rear soffit vents have baffles installed and not the front so I want to fix this. The issue is this, when I pulled the front insulation back I noticed that the soffit vent is approximately 8-10 feet lower then the attic floor since I have a vaulted ceiling. There are baffles installed but they should have probably installed several to reach the attic which they did not. If I leave the batt insulation out of this space then the ceiling in my kitchen will not be insulated. Is there any way to slip the baffles down into this space to create air flow to my attic???? I was thinking of maybe trying to push the insulation back down and slipping the baffle in behind it somehow but not sure if this will work! PLEASE HELP!
jamjr74 is offline   Reply With Quote
Old 01-25-2012, 03:46 PM   #2
AGWhitehouse's Avatar
You description looks like your using the wrong nomenclature which is leading to the belief your house was built upside down. Did you mean to say your soffits are 8-10 feet below your attic floor? Where the attic is over room "XYZ" and the vaulted ceiling is above the Kitchen?
Even if that's the case, pictures are worth ALOT
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 01-25-2012, 03:51 PM   #3
Yeah sorry meant to say soffit vent is 8-10 ft lower then attic floor.
Old 01-25-2012, 03:56 PM   #4
without pictures/sketches I can't say much more than this:
I just put baffles in my attic and they are a real pain to work with even when you can get to where they go in. They are flimsy and cheasy and can break or rip without much effort. So if you are thinking of "sliding them down" and then getting insulation in there, you're probably going to find out the hard way, it's not going to work out like you want it to.
Old 01-25-2012, 03:58 PM   #5
Yeah that's my worry. My home is 20 years old and have not had any issues thus far with mold or moisture so I may just let it be.
Old 01-25-2012, 04:00 PM   #6
Sometimes the old saying (If it ain't broke, don't fix it) applies. Sometimes...
The Following User Says Thank You to AGWhitehouse For This Useful Post:
Windows on Wash (01-25-2012)
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Adding attic insulation rakuz66 Insulation 4 07-22-2011 05:02 PM
Adding attic insulation rakuz66 HVAC 2 07-22-2011 10:51 AM
Attic Insulation paige2 General DIY Discussions 2 04-01-2011 05:30 PM
Attic Ventilation in 1928 Bungalow stephensandlin Roofing/Siding 1 07-09-2009 11:16 PM
