Attachment Strategies For Rigid Foam Board Over Plaster Ceiling - Insulation - DIY Chatroom Home Improvement Forum
Old 10-10-2013, 01:40 PM   #1
Attachment strategies for Rigid foam board over plaster ceiling
Since I have limited ability to add insulation in my attic and cracked plaster ceilings (no serious damage), I would like to recover it with a 1" layer of foam insulation, 1/2" greenboard and a skim coat of plaster. I plan on securing the foam with 1-1/4" insulation washers from McFeeley's and 3" screws. On top of that I will secure the gypsum with 3-1/2" screws. I do not want to build out the ceiling with strapping because of space concerns. Any advice on screw spacing for each layer from those with experience in securing drywall directly over rigid foam. Also any strategies to avoid hitting washers on foam layer when applying drywall.
frtools is offline   Reply With Quote
Old 10-10-2013, 09:37 PM   #2
Rewards Points: 140
can you get into the attic at all ?
are the ceilings bowed/sagging ?
Fix'n it is online now   Reply With Quote
Old 10-11-2013, 12:11 AM   #3
Registered User
Rewards Points: 4,894
Why greenboard (moisture resistant) rather than "lightweight" 1/2" drywall that spans 24"? Why not remove the plaster and lath, that weighs 8# per square foot plus insulation weight, plus weight of new drywall; you would probably overload the ceiling joists that may be over-spanned if typical in many older houses...
Gary
Old 10-11-2013, 05:57 AM   #4
Rewards Points: 12,794
All that plus why in the world would you want to go over all that with plaster?
Old 10-11-2013, 07:44 AM   #5
PoleCat's Avatar
Rewards Points: 1,638
When I did mine I removed all of the plaster and lath. Installed roll insulation from my ladder rather than going into the attic. R-30 perpendicular to and on top of the joists and R-13 in between. Then I installed the foam board and the drywall together. Drywall jack was essential.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 10-11-2013, 10:35 AM   #6
1) Attic is wide open with original tongue and groove flooring that I do not want to remove. There is already blown insulation under the floow
2) Sorry, I meant blueboard, not green board, blue board is the proper type of board to use under a veneer coat of plaster
3) Not worried about weight and not interested in demoing ceiling to remove perfectly good insulation
4) This method was done by previous owners in other rooms and has produced good results.
Foam Board Insulation issues zpotas Insulation 4 04-21-2012 12:34 AM
Old plaster lath ceiling 1910rowhouse Drywall & Plaster 3 03-30-2012 12:32 AM
Foam board over old 4in thick fiber board roofing panels Rebob40 Roofing/Siding 2 03-05-2012 10:24 AM
Repairing plaster ceiling 3'x5' hole stock2mal Drywall & Plaster 0 01-27-2012 07:14 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
