Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 04-28-2012, 05:41 PM   #1
attaching poly board on concrete block wall
I have a 1960 home and a newly gutted bathroom that has 3/4 inch furring strips 16" OC.I would like to insulate inside of walls (exterior wall) with poly board.
-Is there an adhesive I can use to glue that will not eat up the foam?
-Furring strips are 3/4 inch and so is the poly board ; leaves no space for air escape, is this a problem?
-I also would like to install 6 mill plastic on inside over poly/ furring strips to create a vapor barrier, is this an issue?
thanks
acuts1 is offline   Reply With Quote
Old 04-28-2012, 09:24 PM   #2
Exterior Construction
Windows on Wash's Avatar
There are foam specific construction adhesives that are foam compatible.
Is the existing wall CMU block or concrete?
You do not need a vapor barrier in your case and certainly not on the cold side wall as that would be incorrect placement.
Apply the foam of sufficient thickness and seal all the seam in the foam.
Old 04-28-2012, 11:48 PM   #3
http://www.loctiteproducts.com/p/12/...d-Adhesive.htm
acuts1 (04-29-2012)
Old 04-29-2012, 08:06 AM   #4
-CMU
-What do you seal the foam with?
Thx
Old 04-29-2012, 08:10 AM   #5
What is a good tool for cutting foam; utility knife just seems to shred the foam?
thx
Old 04-29-2012, 08:54 AM   #6
foam.
Regarding the above:
I am installing a bathtub/shower, 1 of the walls will be the exterior CMU with the poly foam board. My plans were to use 6mil vapor barrier behind CBU on both the wood stud wall and the CMU wall.
My question is do I still install the vapor barrier on the cold wall, is this going to create issues?
Thx
Old 04-29-2012, 10:29 AM   #7
Originally Posted by acuts1 View Post
-CMU
Thx
Spray foam is good or regular foam compliant sealant if the gaps are tight.
Foam usually gives you a bit more fudge factor because it is near impossible to make all perfect cuts and joints.
thx
Sharp utility knife works well and you have to cut the foam in multiple passes sometimes to get a clean cut. If you are cutting a bunch of it in a row, some folks use a circular saw but it make a bit of a mess.
Thx
No vapor barrier at all. Not only do you not need a vapor barrier, but the vapor barrier always goes on the warm side wall. In the humid South, that would be the outside wall.
With the foam installed tight to the outside wall and sealed properly, you should not have any moisture diffusion coming through.
Put the foam tight to the wall and be done with it. I would also be cognizant of what type of shower liner combo you are using (i.e. durock with kerdi, etc). If any moisture gets behind the shower, it won't have a place to go to make sure it is a tight wet wall design.
The Following User Says Thank You to Windows on Wash For This Useful Post:
acuts1 (04-29-2012)
Old 04-29-2012, 11:47 AM   #8
i cut mine with an electric kitchen knife. a bread knife works well too if you have one handy.
dwcopple is offline   Reply With Quote
The Following User Says Thank You to dwcopple For This Useful Post:
acuts1 (04-29-2012)
new concrete block wall Ken Mc Painting 1 11-17-2011 10:06 PM
Paint bubbling on concrete block wall hammmer13 Painting 3 10-07-2011 08:55 PM
Thick leveling mortar bed OK for concrete block stem wall? dwoloz Building & Construction 6 02-20-2011 09:44 PM
New window in concrete block wall swill777 Building & Construction 3 08-02-2010 02:28 PM
Concrete Block Wall rag4rdd Building & Construction 2 02-15-2007 12:41 AM
