Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 08-12-2011, 04:18 PM   #1
attached garage
my attached garage has no insulation in the attic.it gets hot in the summer but stays above freezing in the winter.should i insulate it or would it get colder in the winter in the garage
smokeyjoe70 is offline   Reply With Quote
Old 08-13-2011, 10:19 PM   #2
attached garage
You should insulate..
by insulting the garage should get warmer in winter unless your house leaks a lot of heat into the garage.
CountryCare is offline   Reply With Quote
The Following User Says Thank You to CountryCare For This Useful Post:
smokeyjoe70 (08-30-2011)
attached garage not mike homes Building & Construction 4 07-25-2011 09:35 AM
Questions regarding wiring 220 to attached garage... John Green Electrical 0 01-20-2011 10:23 AM
OSB over sheetrock in attached garage Badfish740 Building & Construction 6 01-15-2011 04:37 PM
100 amp Attached Garage Sub Plan KevinBeamer Electrical 18 10-04-2009 09:11 AM
Attached Garage Wall Cracks bkikkert Building & Construction 6 07-23-2008 09:33 AM
