Is This Asbestos Insulation? - Insulation - DIY Chatroom Home Improvement Forum
Old 08-29-2011, 08:36 PM   #1
is this asbestos insulation?
I didnt even think about it until i had it bagged...seems like its fiberglass and i know asbestos can be stretched which this just breaks apart but im more curious then anything...does this look like asbestos insulation?
joseph2293 is offline   Reply With Quote
Old 08-29-2011, 08:46 PM   #2
Licensed Builder
Handyservices's Avatar
Looks like old rockwool insulation used many years ago...
I would use a good respirator and long sleeves when dealing with the stuff, then gooseneck-tape-seal-it in regular black contractor bags for good measure.
Handyservices is offline   Reply With Quote
Old 08-30-2011, 05:01 PM   #3
i used just a respirator used for dusty environments...i did a little research and if its rockwool there is a very slim chance of it containing asbestos since rockwool is a man-made material...
are you pretty certain that its rockwool?
Old 08-30-2011, 05:45 PM   #4
Licensed Builder
No. Just basing my opinion on the look of it.
Old 08-30-2011, 05:51 PM   #5
DIY staff
Rewards Points: 7,174
My vote is the same----nasty itchy but not asbestos.
Old 08-30-2011, 06:32 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,634
Most likely, not.
Treat it as such when it comes to PPE regardless. Fiberglass is not much better for you.
Old 08-30-2011, 08:06 PM   #7
thanks for the posts...there wasn't much of it there just in the sill areas around my finished basement...kinda freaked me out though a little bit
The Following User Says Thank You to joseph2293 For This Useful Post:
oh'mike (08-30-2011)
ASBESTOS..... lots of questions. Dyoung Building & Construction 22 02-14-2012 05:15 PM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
blow in insulation question Cool user name Remodeling 4 12-30-2010 11:24 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
Encapsulating old asbestos vinyl tile Familypro40 Flooring 17 03-22-2009 03:20 PM
