Any Issue With Using 2 Layes Of 1" XPS? - Insulation - DIY Chatroom Home Improvement Forum
Old 07-22-2013, 11:47 AM   #1
Any Issue with using 2 layes of 1" XPS?
2" XPS T&G is special order only in my area. Is there any issue to just putting on two layes of the 1" stuff? This is for a basement finish in Chicago.
ryanmcl is offline   Reply With Quote
Old 07-22-2013, 09:28 PM   #2
Rewards Points: 236
i don't see a problem with it. as long as its touching well = no air gap.
btw, they have it at the menards in homer glen. the 2" stuff.
Fix'n it is offline   Reply With Quote
Old 07-26-2013, 11:19 PM   #3
Registered User
Rewards Points: 526
Need R-10 XPS if no stud wall with R-13 batts, Zone 5; http://publicecodes.cyberregs.com/ic..._11_sec002.htm
http://www.buildingscience.com/docum...r-requirements
R-5 XPS good only to 33%RH at 68*F room air.m Use more foam/less RH.
Gary
Old 07-26-2013, 11:32 PM   #4
Thanks gary, I'm underway using 2 layers r-5 xps, stud wall and r13 roxul to meet close.
Trane XR90 issue jasun HVAC 7 10-08-2012 06:18 PM
HVAC condensor fan outside intermittant wheelsup HVAC 21 05-24-2012 10:25 AM
Westinghouse furnace issue joe8918 HVAC 9 12-04-2011 05:50 PM
how to reduce mositure issue on basement? diy001 Building & Construction 0 10-28-2011 12:44 PM
Perplexing AC issue AvalonGirl HVAC 22 08-17-2011 06:49 PM
