Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 08-24-2011, 09:56 PM   #1
another basement question
Hi guys, first time poster here, but Im very excited to get started on this board. I am about to start turning a room in my basement into a master bedroom with a bathroom. I have read several threads on this subject, but I am still a little unsure what I should do.
In the room Im planning on remodeling, we have had some water in there before, maybe once or twice a year. It usually happens after we have a ton of snow on the ground, then we get a big thaw followed by a rain. I have a contractor friend of mine doing some work for me to get the project started. He cut and jack hammered some concrete to put in a tile along the inside of the block wall and is running that into a sump pump (which we've never had before), and is also running all the plumbing lines and running them into a basin pump style up flow system for the tub/sink/toilet.
Here is my concerns and I hope you guys can help me here. Part of my basement walls are rock foundation, and part of it is block. I have read where you should use a rigid foam board and put the new 2x4 walls directly against the foam board. My problem with this is, my wall in not the flatest for a tight seal. I am planning on putting the 2x4 wall 2" away from the 2 outside walls, so could I just use a batt insulation since it will not touch the actual block/rock wall? The outside walls will have drylok applied to them as well. Also, will I need a vapor barrier if I use a batt insulation? Or, should I just use a 1" or 1.5" rigid foam board against the block/rock wall, and still leave the small gap between the foam board and new 2x4 wall?
Im sorry for the long drawn out post, but I know you guys can help. Thanks so much, and I love this site!
brewcrew is offline   Reply With Quote
Old 08-25-2011, 04:51 PM   #2
m1951mm's Avatar
I noticed that you have not had any answers as of yet. I am wondering if you posted your question under a heading that does not get that much traffic. Maybe try Remodeling or Carpentry as it seems to me your questions fit those headings better than Insulation.
Mickey
Fantasy Walls and Windows
m1951mm is offline   Reply With Quote
Old 08-25-2011, 05:17 PM   #3
Thank you for the advice, I will try in another section
Old 08-27-2011, 11:57 PM   #4
Moderator
No vapor barriers below grade in basements. Lots of reading for you on similar; http://www.buildingscience.com/docum...lation-systems
Drylock will force the water to find a way in elsewhere.
Gary
Clothes taking longer to dry?
Question on basement wall/foundation height iub98 Building & Construction 6 07-15-2012 11:15 PM
Basement shower plumbing question. medicmike Plumbing 5 01-28-2012 05:40 PM
How to - prevent basement mold crazymountain How To Guides 31 01-20-2012 08:59 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
Basement sloping and subfloor install - question globus999 Building & Construction 2 06-17-2010 02:17 PM
