Another Basement Insulation Question - Insulation - DIY Chatroom Home Improvement Forum
Old 01-03-2013, 05:16 PM   #1
Hey everyone. I have have scoured the board looking for an answers to a fairly specific question so I apologize it is already out there and I just have not found it. So my situation is that I think I was given some bad information and now I am trying to resolve it most efficient way possible. The previous owner started to finish the basement but only got as far as putting up the studs. During the home inspection, the inspector pointed out that the previous owner put the studs right against the block wall and did not use PT wood. The inspector told me that I should replace the studs with PT and waterproof the block. So that's exactly what I did. Since then, I have also installed electrical outlets. I was trying to figure out the best way to add insulation now before finishing with drywall when I learned I should have added foam prior to putting the studs back up and I should have left a 1-2" space from wall to studs. Considering that I have used waterproofer and PT wood, would it be worth the time and money to take the wall down and start all over? If no, what would be the best material to use to insulate? Seems to be foam? (I live in eastern Nebraska) I wish I would have done a little more research before replacing the studs! Thanks in advance for your help!
slugger2504 is offline   Reply With Quote
Old 01-03-2013, 11:57 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,744
How much of the basement is below grade and at what level?
The primary benefit of the rigid insulation is the fact that it will (when done correctly) eliminate the thermal bridge of the wall and the big heat sink and condensation zone as a result.
Have people been insulating for years before rigid foam...yes.
If you sealed up the ribbon/band board areas really well and made sure no outside air was getting into the wall space combined with a very tight drywall approach, you should be fine. Be sure to use and unfaced batt insulation if you leave it as it.
The waterproofing membrane is very likely a Class I vapor retarder at this point.
Tags
basement , insulation , stud wall , waterproof
Basement finishing Insulation question. mopar44o Building & Construction 12 01-04-2013 03:30 PM
Basement Wall Insulation Question doublejz Insulation 2 12-17-2012 12:38 AM
another basement insulation question, with a twist? Amateuralex Insulation 1 04-17-2012 03:11 PM
basement with garage insulation question WS6transAm General DIY Discussions 7 01-21-2011 06:15 PM
yet another insulation question bobbyhill Building & Construction 2 12-06-2006 12:01 PM
