Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 12-01-2012, 05:13 PM   #1
Question
Another Basement Insulation question
Hi Guys this is my first time in this forum.
I'm doing a sound proof room in my basement and the framing that was installed is 2X3, so what R value should I use?
I live in montreal canada so it gets pretty cold.
Also would it be ok to put the insulation directly on the concrete and put the vapor barrier after or should I put plastic against the concrete then the insulation and plastic again?
thank you
Bassike is offline   Reply With Quote
Old 12-01-2012, 05:53 PM   #2
The insulation should never touch the fondation. With just 2 X 3's your going going to be able to get much insulation in there.
There has to be over 2000 post already on here about that one subject.
Go back up to the search funtion at the top right and check it out.
Old 12-02-2012, 01:32 PM   #3
sound proofing is not necessarily an insulation question, though insulation can help. as joe said, do a search for both; tons of info.
Old 12-03-2012, 09:26 AM   #4
Exterior Construction
Windows on Wash's Avatar
thank you
Only if the insulation is a rigid foam.
If so, depending on type and thickness, you do not need the poly vapor barrier.
Sound is usually more impacted by the interruption of vibrations through the framing as compared to the insulation schedule.
another basement insulation question, with a twist? Amateuralex Insulation 1 04-17-2012 04:11 PM
Insulating your attic Bob Mariani How To Guides 2 03-01-2012 06:56 PM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
basement with garage insulation question WS6transAm General Discussion 7 01-21-2011 07:15 PM
yet another insulation question bobbyhill Building & Construction 2 12-06-2006 01:01 PM
