Amount Of Heat Loss Worth Caulking? - Insulation - DIY Chatroom Home Improvement Forum
Old 01-29-2014, 01:37 PM   #1
Amount of heat loss worth caulking?
Amount of heat loss worth caulking?-image-1494195527.jpg Ugly ceiling I know... And paneled walls I know, but drywall is not in the budget at this time. Older house built in the 70's. Plenty of blown in cellulose insulation in the attic. How much heat loss could occur in those spaces between the molding and the ceiling tiles? Worth my while to spend an afternoon caulking? Thank you in advance.
Queefer is offline   Reply With Quote
Old 01-29-2014, 05:25 PM   #2
Rewards Points: 13,458
Depends on what's under that paneling and ceiling.
If it was over drywall that was taped then there should be no leaks.
May be able to tell some what by going in the attic to see if you can see the back side of drywall and pushing on the drywall to see if it flexes between the studs.
Old 01-30-2014, 04:27 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,170
Without knowing whats behind it like Joe said...might be like putting bubble gum in a dam leak.
Old 01-30-2014, 05:28 AM   #4
There's no drywall. Looks like maybe just a 2x4(top of framing?). None of the blown insulation from the attic is able to fall through.
Old 01-30-2014, 08:04 AM   #5
What's on the back side of that paneling?
If there's no insulation in that wall just the energy savings if you removed it and insulated it would soon pay for a few sheets of drywall.
I can see where that type ceiling would be real fun to try and clean.
If I had to do any caulking I would remove that cove moulding, caulk it then reinstall it.
Queefer (01-30-2014)
Old 01-30-2014, 08:25 AM   #6
Thank you for the reply. It's an interior wall, so no insulation is behind it, just wall studs. My concern is heat loss rising through those cracks. I may go ahead and caulk it anyway just for cosmetic reasons, even though it's gonna take about 47.3 tubes of it. Lol
Old 01-30-2014, 08:39 AM   #7
I'd use Alex 230, take your time, apply it, wipe with your finger, when wipe down with a damp sponge.
Heat Loss through attic to Roof on top of Shower, Please Help yogi29m Building & Construction 0 02-05-2013 03:55 PM
Heat loss from skylights MrSherry Insulation 7 01-27-2013 01:19 PM
Thermal leak detector new toy.. shocking heat loss or just the norm? windowguy Building & Construction 3 01-17-2012 01:13 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Recessed/Can Lighting Heat Loss? TomServo HVAC 55 11-14-2009 08:23 PM
