Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 06-07-2012, 07:15 AM   #1
Airghtight drywall using acoustical caulk?
Good morning everyone,
I am planning to caulk around the perimeter of walls and all outlets etc primarily for soundproofing purposes.
I am planning to use Sheetrock brands Acoustical Sealant as seen here:
http://www.usg.com/sheetrock-acoustical-sealant.html
– Excellent sound-flanking material (supports high STC ratings)
– Superior performance as a fire caulk in UL-classified joint systems
– Ideal for use in smoke and/or sound assemblies
– Meets ASTM C834 specifications for latex sealants
– Grade -18°C (0°F) low temperature flexibility, strong bond
– Low VOC
Per MSDS, This latex acrylic caulk contains mostly limestone, acrylic polymer, and butyl benzyl.
It sounds like some pro's recommend using poly caulk for airtight drywall installation. My question is could I used the acoustical caulk instead and achieve same results as poly caulk? At the end of the day, I was hoping to kill two birds with one stone and achieve some level of soundproofing and good "thermal" barrier/no air draft.
Thank you in advance.
sbkim is offline   Reply With Quote
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
Does mold grow on or in uncured caulk ? TheITloveswood Flooring 11 09-08-2011 06:28 AM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
Should I Caulk Gap Between Drywall and Subfloor? sweaty Building & Construction 1 08-11-2011 11:25 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
