Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 04-30-2012, 09:32 AM   #1
Checking things out
Air Sealing Subfloor Joist Space - Foam Board?
I'm in the process of air sealing my house before adding to the existing insulation. Among other sources of information, I've found the book Insulate and Weatherize by Bruce Harley to be an excellent reference. In a few spots, he recommends using rigid foam board to effectively air seal larger openings including subfloor joist spaces that are completely open to unconditioned air in the attic over an attached garage. The attached photo shows an example of what I'm trying to block in my attic.
I'm concerned, though, that almost everything I've read about rigid foam board insulation says clearly that it must be covered by a fire barrier such as 1/2" drywall. If I were to install this in the joist space as an air barrier, would I also have to install drywall on both sides of the foam board in order to meet the fire barrier requirement?
Any other recommendations on how to properly seal off the subfloor joist space from the unconditioned attic air to help with my air sealing efforts?
FWIW, I'm in the Dallas area...
Thanks!
-Mason
masonbrown is offline   Reply With Quote
Old 05-01-2012, 09:36 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rigid foam blockers, spray foam and seal edges, cover with some fiberglass.
The plywood servers as your thermal barrier (although you really only require an ignition barrier in this case) and the fiberglass covering the foam will serve as your ignition barrier.
Get the foam tucked right to the edge of the warm wall and seal it there.
Old 05-06-2012, 04:54 PM   #3
Checking things out
Thanks, that makes sense!
-Mason
Installing foam board around windows ? Arky217 Windows and Doors 3 09-12-2011 05:13 PM
rigid foam board on basement floor is it good or bad cutnail Insulation 6 08-29-2011 08:48 AM
Best adheasive for foam board to concrete BlueBSH Building & Construction 1 08-05-2011 04:06 PM
Venting foam board insulation mbscallen Building & Construction 5 02-15-2008 09:18 AM
